Slimy38
posted on 8/9/12 at 08:49 PM |
Eezibleed - what am I missing?
I bought an Eezibleed to do my tintop brakes on Friday, came to use it this morning and couldn't get an airtight seal. The cap itself sealed
fine on the reservoir, but where the pipe attaches to the cap it wouldn't seal. I'd sprayed a bit of water around the cap and could see
bubbles coming from the little washers.
I know from my brother in law plumber that sometimes making things as tight as possible isn't the best way to seal things, but I tried
everything from hand tight up to f**king tight, and it still wouldn't seal. In the end I declared it faulty, and got a replacement from
Toolstation.
Everything on the internet suggest the issues are more where the cap fits to the reservoir, but I'm fairly sure that is actually ok. If it had
been leaking there I doubt I'd have seen bubbles coming from the washers.
I've not yet fitted the cap on the new one, but is there a 'knack' to attaching the pipe to the lid?
Wheels244
posted on 8/9/12 at 09:00 PM |
I had one years ago - I never could get it to work properly.
Sorry, probably not the news you wanted to hear.
I rely on the good old mate pumping the pedal and tube into a jam jar technique.
100% success rate.
posted on 8/9/12 at 09:16 PM |
I had some leakage where the cap meets the bottle but some PTFE tape did the trick. Not sure about your leak though!
Ben_Copeland
posted on 8/9/12 at 09:32 PM |
What pressure are you using in your tyre? If its too high you'll blow the seals in the easibleed.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
spiderman
posted on 8/9/12 at 09:34 PM |
How much air pressure are you using? I had problems when using too high a pressure. Try using a really low pressure like 2psi or there about, worked
for me. Also make sure the brake pedal is depressed as the pressure has nowhere to go and just pressurises the reservoir.
[Edited on 8/9/12 by spiderman]
Spider
wylliezx9r
I've used mine about 5 times with a home made cap so that it will fit the Lucas reservoirs. Never had a problem. Are you using too much
pressure ?
HTH Dan
George Best
posted on 8/9/12 at 09:41 PM |
i thought it was 20psi it needed, but either way, it doesnt matter if its leaking, so long as some pressure is pushing the fluid through. Its a
brilliant system i thought, a muppet like me managed to do my brakes first time with no bother.
posted on 8/9/12 at 09:50 PM |
Low pressure is important, with mine I had less than 10psi in the tyre (I used an old trailer wheel to supply the air).
Really, all you need is a few psi over atmospheric to get the fluid through.
[Edited on 8/9/12 by David Jenkins]
ashg
posted on 8/9/12 at 10:22 PM |
ptfe tape will sort it. i have converted mine to run off my compressor, it is so much more usable now as i can control the air flow perfectly
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
maccmike
posted on 9/9/12 at 12:09 AM |
My dad bought one, I used it, it was brilliant.
Bought my own, same supplier, same brand, it was sh1t.
Bare
posted on 9/9/12 at 01:23 AM |
Waste of time and money :-) Buy a cheap disposable 2 oz Plastic syringe.
Use it to reverse flush the Brakes on ANY vehicle.. Fill it with fresh Fluid, Attach it to the subject bleed nipple. Open the nipple a half turn
then 'force' the fresh fluid in. It;s slowish So don't be in a massive rush.
But it Works ! every time.
RichardK
posted on 9/9/12 at 01:39 AM |
Surely that would take ages to flush an entire system Maybe ok if you suspect air at one the corners though or if you pumped through all the old
fluid out first and then ran some fresh through.....
Mine also squirted fluid from the top as I used too higher pressure at first, think I used about 10 psi, worked great after that.
Rich
Gallery updated 11/01/2011
Slimy38
posted on 9/9/12 at 08:08 AM |
Thanks for the replies everyone. I started with 10 PSI, I'd seen a Youtube video where they do an old Beetle so I thought it sensible to start
at the same number they quote.
Is PTFE tape safe for brake fluid? Alternatively, if I follow JoelP and accept the inevitable slow leak, would a few rags wrapped around the pipe
catch any overflow? I'm guessing depending on how quick I can be I might not be looking at too much coming out, and I've got 2 litres to
finish the job with.
I should mention that it's a VAG car (SEAT Toledo) with a hydraulic clutch in the circuit, and an 'odd' master cylinder design.
Apparently if you try standard two man bleeding, it's remarkably easy to reverse the seal on the master cylinder and then the whole thing has to
be stripped down. You've also got an ABS system that requires electronic bleeding if any air bubbles get into it, and it's been quoted
that pressure bleeding is the safest option to avoid that.
That and the fact that I've never done car brake bleeding before suggests that the 'eezier' the bleed is, the safer it will be.
Bare, I understand the principle of reverse flushing, but how do you confirm whether it's flushed out all the bubbles? Even when you attach the
syringe, you're introducing an air bubble then forcing it into the system.
40inches
posted on 9/9/12 at 08:59 AM |
As said, low pressure needed or it will leak. I have an Eezi bleed and a vacuum oil pump, the vacuum pump is more reliable for
bleeding brakes, plus if you get a system that will not bleed ( midi engined car clutch i:e MR2) using both in combination will
always work.
neilp1
posted on 9/9/12 at 09:45 AM |
I had same problem even at 10psi, so binned it!!
chillis
posted on 9/9/12 at 09:53 AM |
Wouldn't be without mine, bought it in the early eighties and is probably the best tool I ever bought.
use at low pressure 7psi is about 1/2 an atmosphere and makes it very controlable. I think people crank up the pressure 'cos think they'll
be able to do the job quicker.
I do have a few bubbles where the air pipe goes into the bottletop but nothing leaks from the M/C cap. Make sure you have assembled the seals and
washers correctly. If you're using a modified cap from the vehicle make sure you file down the top of the cap nice and flat. Has it worked ok
previously, you never know it could be afaulty one.
Throughout my automotive career I have use vasious other types including the (useless) vacuum types with varying lack of success but I always come
back to the easibleed.
Slimy38
posted on 9/9/12 at 10:41 AM |
All sorted now. The second cap bubbled at the same point as the first one, but all it meant was that there was a tiny pool of fluid on top of the cap,
and the reservoir itself filled up to the brim. I just got on with it, and released the pressure between wheels. Keeping things mopped up meant that I
lost very little, and the paintwork is still intact.
The amount of rubbish that came out was scary, it was at least two shades greener than it should have been (the new stuff is yellow!), it was really
frothy and there was definite debris in the pipes. Not had chance to take it for a run, but starting the engine and pressing the brake pedal showed
there was resistance so I can't have done that bad a job!
All hail the Eezibleed!!
Autosri
posted on 9/9/12 at 11:12 PM |
used mine again today for about the tenth time absolutly brilliant i start it at 23psi and by the time you have pushed over a litre its down to 18psi
i had a few leaks the first time but were easily sorted i dont even bother with any onther method as the gunson just works i even have a proper vaccum
bleeder and the gunson is better imo
dhutch
posted on 18/9/12 at 11:21 AM |
They are fairly poor, but do work, sticky tape, cable tie round the pipe, get it good enough and then get on with it, and use the spare (or have a
pump).
Daniel
Mr Whippy
posted on 18/9/12 at 11:34 AM |
only thing that works for bleeding the landys brakes, they do tend to spring leaks but easy to sort
SeaBass
posted on 18/9/12 at 02:23 PM |
I do remember a bit of fiddling when I first got it but mine works great every time - used it on countless projects.
SWMBO point blank refuses to get involved with the old up down up down and I have no mates...
Rgds
posted on 18/9/12 at 03:35 PM |
I've had an Ezibleed for ages - last time I tried to use it I found that the rubber washer on the 'reserve tank' was misshaped and
wouldn't seal. I assumed that I had messed it up when I last used it by not ensuring that it was seated properly when I tightened it and put it
away (almost certainly).
I sent an email to Gunsons explaining the problem - and they sent me a replacement free of charge by return post. You really can't argue with
customer service like that!
Slimy38
posted on 18/9/12 at 05:21 PM |
quote: Originally posted by SeaBassSWMBO point blank refuses to get involved with the old up down up down and I have no mates...
Rgds
Snap on both points, although neither of them are really to do with the Eezibleed...
