Author: Subject: cosworth diff viscous fluid
needforspeed
posted on 10/9/12 at 11:38 AM Reply With Quote
does anyone know what fluid/grease do you use between the plates??
ReMan
posted on 10/9/12 at 12:37 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=174126
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
ajw
posted on 10/9/12 at 06:48 PM Reply With Quote
diff fluid
The fluid is a silicone based fluid that thickenss when heated. I had a sierra cosworth diff pumped by Phil Jones Engines & transmisions in Chipping Sodbury (see website). It works well but I now run a 4.4 with a titan diff as the viscous was not good enough on a hillclimb MK. Perfect for a road car as plate type can push front out in tight corners if throttle is planted to soon.
needforspeed
posted on 10/9/12 at 06:57 PM Reply With Quote
thank you! how much did it cost you?
