Author: Subject: polo rad
oliveoil
posted on 24/9/12 at 07:06 PM Reply With Quote
polo rad
hi everybody this is my first post i have velocity xt, i am trying to fit polo rad and it is not going very well, can anyone help. thanks les
adithorp
posted on 24/9/12 at 07:15 PM Reply With Quote
Welcome.
Whats the problem fitting it?
http://jpsc.org.uk/forum/
oliveoil
posted on 24/9/12 at 07:23 PM Reply With Quote
To wide to go in between the original mounts. The bottom hose outlet of the radiator and radiator fan switch touches the chassis.Tnaks Les
wilkingj
posted on 24/9/12 at 07:30 PM Reply With Quote
Hi, can you put your approx location in your profile, as it will help others to help you.
Cant help on the Velocity, I'm a Viento man myself.
Shouldnt be too hard to sort,
Best Regards
Geoff
http://www.v8viento.co.uk
big_wasa
posted on 24/9/12 at 07:31 PM Reply With Quote
The xt is more or less an Irs locost. This is a polo rad in my locost.
[Edited on 24/9/12 by big_wasa]
oliveoil
posted on 24/9/12 at 07:47 PM Reply With Quote
polo rad
hi big wasa mine has two brackets going from the top chassis rail to bottom rail thanksles
posted on 24/9/12 at 07:49 PM Reply With Quote
Which Polo rad do you have as there are a few different ones?
oliveoil
posted on 24/9/12 at 08:01 PM Reply With Quote
polo rad
hi rusty nuts its the smallest one with 380mm core thanks les
snapper
posted on 25/9/12 at 06:20 AM Reply With Quote
You need to adapt the brackets you have or
Make new ones for the radiator and bolt them to the originals or
Cut the old ones off and weld new ones to the chassis.
There are many ways to skin a cat and with kit cars as you will find out every problem is specific to your car but can be solved with a bit of lateral thinking
A photo speaks a thousand words so your first task is to work out how to post photos on this forum which is much harder than most jobs you will have to do on your car
I eat to survive
I drink to forget
oliveoil
posted on 25/9/12 at 06:42 AM Reply With Quote
polo rad
hi snapper thanks for the info will try and post a photo thanks les
loggyboy
posted on 25/9/12 at 07:52 AM Reply With Quote
This is the one that is generally used:
VOLKSWAGEN POLO 1983-1990 / DERBY / SEAT TERRA RADIATOR NEW - 2 YEAR WARRANTY | eBay
Our part number - VW302E.
Original Seat / Volkswagen part number(s) - 867.121.253 F.
Approximate core size - 380mm x 320mm.
Mistral Motorsport
Neville Jones
posted on 25/9/12 at 11:30 AM Reply With Quote
There's a number of different POLO rads, all got the similar vw 121.253 part no., but the last letter differentaites them. I've bought most by mistake.
Some are thicker as well, 34mm vs 23mm.
The Valeo catalogue I have lists the 430x322 and the 380x322 as both having been fitted in the 81-86 and 86-90, 1.05 and 1.3 Polo's.
Valeo no. 883818 for the narrower, and 883819 for the wider. These are 34mm core rads.
Nev.
oliveoil
posted on 27/9/12 at 08:16 PM Reply With Quote
POLO RAD
Hi everyone thanks for all the info am on holiday abroad at the moment will get back to you all when i return les
