AndyW
posted on 25/9/12 at 04:56 PM |
WTD: M8 x 50 allen head bolt high tensile threaded all the way
I need 4 M8 x 50 allen cap bolts which have the thread all the way from top to bottom. I also need them to be high tensile. Or if anyone has a M8 x 50
MACHINE SCREW that would be even better
If anyone has any knocking about please let me know
Thank you
[Edited on 25/9/12 by AndyW]
redscamp
posted on 25/9/12 at 06:09 PM |
sorry to be a pedant but
machine screws are threaded all the way
bolts have a plane bit by defintion
AndyW
posted on 25/9/12 at 06:30 PM |
I have edited my want, so as to not cause any confusion.
Anyway I still need machine screws/bolts/set screw call it what you may but I NEED SOME!!!
Wadders
posted on 25/9/12 at 07:15 PM |
If you want to be really pedantic, they are actually 'set screws'
machine screws are normally low tensile, and have cheese, slot or pan heads, etc.
To answer the OP, have you tried orbital fasteners? i can recommend them
Al
]Originally posted by redscamp
mcerd1
posted on 25/9/12 at 07:35 PM |
almost all allen headed ones are grade 12.9 anyway (unless they are stainless) so they are fairly standard item that you should be able to get from
any decent bolt supplier
I got similar ones for my driveshafts (M8x50 Gr12.9 ~30mm thread) from a local builders merchants for a few pennys each
[Edited on 25/9/2012 by mcerd1]
zetec-phill
posted on 26/9/12 at 12:04 AM |
Get in touch with BAPP they are a company in kirkby -in- ashfield notts they must retail at about 10P each!!!!!
RickRick
posted on 26/9/12 at 06:01 AM |
This place has them, seem to be quite cheap and quick service too
http://www.jandsfasteners.co.uk/PBSCProduct.asp
there £3.03 for 100
