Author: Subject: Zetec + MT75, 'ow much do they weigh?
Browser
posted on 26/9/12 at 12:12 PM Reply With Quote
Gents, as title, anybody any idea of the combines mass?
I will shortly be leaving my place of employ and it's handy 500kg engine crane. I have managed to obtain a 500kg set of chain blocks and am intending to bribe the scaffolding contractor into letting me take some poles & clips to build a couple of A-frames out of to lift heavy things as and when I need to. I've seen them rig lifting beams around site before using doubled-up poles clamped together and was intending to copy this, but wanted to know the weight that would be suspended so I could verify that doubles-up scaff poles would be up to the job.
Anyone weighed their Zetec & MT75 or know the weights please?
loggyboy
posted on 26/9/12 at 12:23 PM Reply With Quote
IIRC the zetec is about 120kg and if the image below is correct the dry box is only 30kg, even with ancilarrys and fluids I cant see it being more than 40kg.
I whipped out an XE (135kg) with single cantilvered scafold pole. only deflected about 10-15mm.
[Edited on 26-9-12 by loggyboy]
Mistral Motorsport
Chippy
posted on 26/9/12 at 04:33 PM Reply With Quote
I lifted two 1.8 TDI Ford lumps, (one at a time), with just one pole held between two supports approximately 6 feet apart, did bend slightly, but once the weight was off it returned to straight, so didn't bend enough to deform the tube. I would guess that they are somewhat heavier than a Zetec. HTH Ray
Browser
posted on 26/9/12 at 07:05 PM Reply With Quote
Thanks for the replies guys, I will equip myself with a sufficiency of scaffold tubes before I leave.
Nickp
posted on 26/9/12 at 07:42 PM Reply With Quote
I've got doubled up scaffold poles spanning my single garage, so 8-9ftish. This easily supportss a iron blocked Camry V6 engine and box and done a straight 6 BMW engine and box no bother, so a measily 4 pot should be a doddle
snapper
posted on 27/9/12 at 07:42 AM Reply With Quote
I ran two short scaffolds across two roof beams then one pole across the scafold forming an H section
This was very strong
I eat to survive
I drink to forget
