Author: Subject: Tracing Crossflow engine
wdavie
posted on 30/9/12 at 08:16 PM Reply With Quote
Hi guys I have a 1600 xflow in my kitcar and want to trace the engine, ie which car or year it's from, does anyone know how to do this. Cheers
perksy
posted on 30/9/12 at 08:29 PM Reply With Quote
You can Date it on the Burton power website
http://www.burtonpower.com/tuning-guides/tuning-guide-pages/ford-manufacture-dates.html
wdavie
posted on 30/9/12 at 08:35 PM Reply With Quote
Must have read my engine umber wrong as I seem to have a number that doesn't match, it's 691M 6015BA will have to check again. Thanks for help.
johnemms
posted on 30/9/12 at 08:40 PM Reply With Quote
Casting date on block behind alternator ..?
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
snapper
posted on 30/9/12 at 09:15 PM Reply With Quote
The number you quoteis a casting number
You need to find the Engine number which is stamped on a flat bit
It will have 2 letters first which are interpreted using the Burtons Ford age chart
As for where it came from, Cortina MK2 through Escorts to Fiesta and I believe a derivative in the Ka
I eat to survive
I drink to forget
chillis
posted on 1/10/12 at 09:15 AM Reply With Quote
Thats the block part number - Pre 1971 1600 from a MK2 Cortina or Mk1 Capri
Fiesta's are 761m and front drive only - no RH engine mount pads
Ka engines are HCS and totally different
Never under estimate the ingenuity of an idiot!
posted on 1/10/12 at 10:14 AM Reply With Quote
Look down on the engine from the exhaust side.
Just under the exhaust for number 1 cylinder, at the front of the block where the head sits on it, is a little cast 'bump out' that usually has a machined flat surface on top. This is about 2" long and 1/2" wide.
On this you should find 2 letters and a number (5 or 6 digits maybe?) - for example, "AB12345" - this is the engine number.
I tried to find a picture of mine, but failed...
[Edited on 1/10/12 by David Jenkins]
wdavie
posted on 6/10/12 at 07:07 PM Reply With Quote
Cheers guys will have a look next time I'm at lock up. Wayne
