New Topic New Reply
Author: Subject: Which sump Is this?
Sierra
posted on 3/10/12 at 11:11 PM Reply With Quote
Which sump Is this?
I guys I've got a zetec blacktop and I have found a tiny hair line crack in my oil pan which is leaking a small amount of oil. Can any tell by these pictures which zetec engine it's off because every zetec pan I've seen for sale is a different shape.
Macbeast
posted on 4/10/12 at 06:39 AM Reply With Quote
Looks as if it has been modded to reduce height ( and not quite enough )
Nick DV
posted on 4/10/12 at 06:42 AM Reply With Quote
Probably a standard sump, but looks to me that it's been 'cut and shut' a fair bit. By the look of the bottom, it's been hit a few times, so has a weld cracked and is it leaking at that point? I would just take it off and repair the crack with a fresh weld.
Cheers, Nick
"The force will be with you, always!"
Xtreme Kermit
posted on 4/10/12 at 06:50 AM Reply With Quote
Yup. Modified blacktop zetec.
snapper
posted on 4/10/12 at 07:14 AM Reply With Quote
A CVH sump fits
I eat to survive
I drink to forget
Sierra
posted on 4/10/12 at 08:26 AM Reply With Quote
Thanks guys, yeah it looks like its been cut and re shaped for clearance but it still sits very low, what have others done.
Problem I've got now is how would I get another one the same (I don't weld), can it be welded as its soo thin and will probably blow a hole.
Or has anyone ever used the liquid metal products as this is a very thin hairline crack.
It's difficult to read the oil level as dipstick always shows it as over filled
Macbeast
posted on 4/10/12 at 08:46 AM Reply With Quote
I don't see any extension to restore some of the lost sump oil capacity.
The reading on the dipstick should not be affected by the mod - the dipstick measures from the block downwards to the oil surface and this should still be the same.
A proper garage workshop should be able to MIG weld it for you for peanuts ( Thoroughly clean it and de-rust before taking it in )
[Edited on 4/10/12 by Macbeast]
loggyboy
posted on 4/10/12 at 08:53 AM Reply With Quote
Similar to what I did on mine, but with single plated bottom, where as mine used part of the original.
http://locostbuilders.co.uk/viewthread.php?tid=149348 (near the end of that thread)
Looks like its about as short as it can be without loosing too muhc volume so you might want to add some sort of sump guard.
Mistral Motorsport
loggyboy
posted on 4/10/12 at 08:55 AM Reply With Quote
There is a fair amount, whilst the standard sump is fairly deep, it is only deep half way accross its width, the other half is almost completely flush with the upper edge.
Mistral Motorsport
Sierra
posted on 4/10/12 at 08:58 AM Reply With Quote
Doesn't the dipstick go to the bottom of the pan and if that's been shortened it will read as if its got more than it has.
Is this my sump below? Looks like an odd one as half is flat and mine isint
loggyboy
posted on 4/10/12 at 09:09 AM Reply With Quote
http://i50.photobucket.com/albums/f340/s18rra/BBF62B84-0E2A-4546-B408-9E09BB43C3B2-569-0000002295734ABD-1.jpg
That is likely to be what yours is based on, when yours was modded the deep area was cut short and the flat area was made larger, so it should have kept roughly the same amount of oil as the original, despite being cut shorter. As the volume is roughly the same ,the dipstick level will also remain the same. The dip stick doesnt meaure the bottom of the pan, it measures the oil level, which will be near the top of the sump.
[Edited on 4-10-12 by loggyboy]
Mistral Motorsport
Sierra
posted on 4/10/12 at 10:39 AM Reply With Quote
Unfortunately I can't put a protection guard as the sump already is the lowest part of the car and is very low. I could however maybe get a plate welded directly to the bottom of the pan to make it stronger when it does get hit.
Does anybody know what metal it's made from as its very thin and can a steel plate be welded to it?
loggyboy
posted on 4/10/12 at 11:10 AM Reply With Quote
Its made of mild steel. I wouldnt weld anything directly to it.
How far is it below your chassis rail? It could be the car it seld is too low, so the other option would be to raise the suspension?
You could still fit a sump guard, this whilst this will be lower than the sump, the idea of a sump gaurd is to get hit, but its mounted to the chassis so it protects the sump from getting damaged, the guard it self is sacrafical, so will get scrapped and bashed but protect the import stuff.
(I have one I picked up on ebay made of 10mm aluminium, its well used and scrapped but is still in shape)
Mistral Motorsport
Sierra
posted on 4/10/12 at 11:22 AM Reply With Quote
Ill measure how much lower it is when I next go to the garage but I think a good inch below chassis.
I suppose I could get a guard made up from someone that drops for the sump and raises up on the sides to attach to the chassis
loggyboy
posted on 4/10/12 at 11:27 AM Reply With Quote
An inch below is about right for a 7.
I think mines about 50mm below (albeit not on the road yet)
I would expect the previous owner was either not very careful, went over too many bumps to quickly.
Repair it and see how you get on with it at the height it is at mo.
Mistral Motorsport
Chippy
posted on 4/10/12 at 03:02 PM Reply With Quote
Looks to me as though the engine/gearbox has been mounted far too low from the pictures, may just be the angle they were taken at though. If the sump is in fact just 1" below the chassis, then the car has been set up too low. Either raise the engine/gearbox or raise the suspesion so the car rides higher. IMHO Ray
New Topic New Reply
