Author: Subject: Garage Clear Out...
mackei23b
posted on 30/10/12 at 09:38 PM Reply With Quote
Garage Clear Out...
Hi there
Garage clear out........
1) Datatool Gearshift (unused as I sold the Megablade before I fitted it) £35
2) Steering Wheel (SVA complaint - it passed the SVA on my car) - fits a Mountny Boss £55 - SOLD
3) Standard Rear Sierra Brake Disks (Unused)£15
Disk for sale
Disk for sale
4) 25mm Wheel Spacers inc studs Ford PCD (Unused) £20
5) Facet Fuel Pump £20
6) Fuel Regulator £15
7) Fireblade Voltage Rectifier (893) £20
Fireblade Regulator (893)
8) Caterham Steering Rack (this does have a little play - spares or repair) £35
All items plus postage at cost or pick up - I live in Chipping Norton and work in Oxford if that is of help??
All the pictures are in my archive, u2u if you are interetsed, thanks for looking....
Ian
[Edited on 30/10/12 by mackei23b]
[Edited on 31/10/12 by mackei23b]
lmillin123
posted on 1/11/12 at 10:07 PM Reply With Quote
What comes with gear indicator?
Norfolkluegojnr
posted on 2/11/12 at 09:15 AM Reply With Quote
Any idea what the flow on the facet pump is?
mackei23b
posted on 16/11/12 at 01:57 PM Reply With Quote
Hi there
I've had a look and it's spec is:
pressure 3.00-4.5 psi,
flows 30 US Gallons per Hour,
0.3 metres Prime Height,
1/8nptf Thread Size.
Ian
mackei23b
posted on 16/11/12 at 02:01 PM Reply With Quote
Hi There
It is as originally supplied, the gear indicator as pictured with the wiring and the instructions, that is all that is needed to install it.
Best regards
Ian
zetec-phill
posted on 16/11/12 at 04:46 PM Reply With Quote
ill have the spacers please... you have u2u
mackei23b
posted on 16/11/12 at 05:26 PM Reply With Quote
Hi there
Quick update on the garage clear out........here is what is still available
Disk for sale
Disk for sale
5) Facet Fuel Pump £20 (Ben has the first option on this)
Ian
locost47
posted on 18/11/12 at 12:42 PM Reply With Quote
steering rack
hi is the rack standard or quickrack
mackei23b
posted on 20/11/12 at 06:58 PM Reply With Quote
Hi there
The rack is the standard +8% Caterham rack, it is about 2.5 turn lock to lock
Ian
