Author: Subject: gauges
Arjan356
posted on 18/9/04 at 08:05 AM Reply With Quote
gauges
Does anybody know were I can find a tachometer that do up to 12000rpm. Preferable with a yellow dial.
I don't want to use the original gauges of the bike, because I want to fill the dash with as many gauges as possible of the same kind.
Arjan
r3nuf
posted on 18/9/04 at 08:16 AM Reply With Quote
Try www.etbinstruments.com.
I have just had a look and they make an electronic tacho that is good for 0-14000rpm. Also it is available in yellow.
RRP incl VAT £76.50
Hope this helps
Gary
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 18/9/04 at 08:50 AM Reply With Quote
yup ive got an etb one on my blade engined indy, black with red pointer.works fine
Ferrino
posted on 19/9/04 at 05:15 PM Reply With Quote
Do VDO do an extended range tacho?
