Author: Subject: My Pinto has a hole in it!!!!
Mark Allanson
posted on 19/9/04 at 06:02 PM Reply With Quote
I decided to fill up my coolant today, just to check for leaks etc.
It has a leak, there is a hole at the front of the LH side of the head that looks like it should have a sensor in it. I cannot remember taking one out, but the hole looks like it is 1/8BSP so a tenp sender is favorite, can anyone confirm? Rescued attachment Leaking Hole.jpg
theconrodkid
posted on 19/9/04 at 06:21 PM Reply With Quote
temp sender
who cares who wins
pass the pork pies
rizla
posted on 19/9/04 at 06:50 PM Reply With Quote
yep thats a temp sender hole
subk2002
posted on 19/9/04 at 07:13 PM Reply With Quote
Ditto
mookaloid
posted on 19/9/04 at 07:34 PM Reply With Quote
yup
Mark Allanson
posted on 19/9/04 at 07:56 PM Reply With Quote
So you all reckon its the temp sender?
bob
posted on 19/9/04 at 10:01 PM Reply With Quote
yup its defo the temp sender,if i can find my old one that matches sierra clocks do want me to post it to you ?
Obviosly no good if your using custom dials though.
Mark Allanson
posted on 19/9/04 at 10:09 PM Reply With Quote
Thanks for the offer, I should be able to get a new one for a couple of quid locally, how have you got on with your 2.0 pinto with the micra radiator? I drove to bristol on friday, normally about a 3 hr drive, but took me 6 hrs with heavy traffic, this is a trip I will do regularly in the locost, just hope that the micra rad will cope with traffic jams OK
bob
posted on 20/9/04 at 09:40 AM Reply With Quote
Mark
I'm using a sealed mk2 escort rad which seems to cope,it does get a bit hot in traffic but so far so good with the stat kicking in and bringing the temp down ok.
I would like the stat to cut in a bit earlier and was thinking of adding a dash switch so i could manually apply when i hit traffic.
I did take some good advice sunday to fit a kenlowe adjustable stat so as to get the fan on earkier which is also an option.
Mark Allanson
posted on 20/9/04 at 07:27 PM Reply With Quote
New sender is now fitted, no leaks, G12 antifreeze, ever such a pretty shade of pink!
