Author: Subject: Zetec Alternator Idler Pully
Alfa145
posted on 6/12/12 at 11:40 AM Reply With Quote
Does anyone know where I can get just the pulley from the Alternator/Drivebelt trensioner contraption?
I don't need all the tensioner stuff just the pulley to use above the water pump pulley so I'd rather not pay a fortune for the whole tensioner gubbins as it's not needed.
Tee pulley I'm after is the one on this I just don't fancy paying £52 for a pulley...
http://www.ebay.co.uk/itm/FORD-FOCUS-1998-2004-DRIVE-BELT-TENSIONER-PULLEY-/190586769206#vi-content
loggyboy
posted on 6/12/12 at 12:10 PM Reply With Quote
Theyre not cheap sadly.
http://www.retro-ford.co.uk/shop/catalog/zetec/starter-and-alternator
Mistral Motorsport
posted on 6/12/12 at 12:27 PM Reply With Quote
Go down the scrappy and grab one?
me!
posted on 6/12/12 at 12:33 PM Reply With Quote
I used one like this, but from a motor factors. Was a bit cheaper if I remember rightly, but I had to get a boss made up to mount it to.
Alternator Belt Idler, Ford Transit Mk5 00>'06 2.0 Diesel Opt2/2 (+)A/C
tims31
posted on 6/12/12 at 12:39 PM Reply With Quote
Hey Alfa145,
I may still have the one I took off my zetec, may be a bit grubby but should do what you want. I will have a look at the weekend when I get home and let you know.
Thinking about it, if you just need the pulley wheel a new one comes with the new cam belt I think????
[Edited on 6/12/12 by tims31]
Build: http://www.martinsfurybuild.co.uk/
tims31
posted on 9/12/12 at 12:04 AM Reply With Quote
yep have one,
U2U me if you still want it
Idler wheel
Idler wheel
davred
posted on 9/12/12 at 09:38 AM Reply With Quote
ZETEC IDLER PULLEY
I USE A QTA1018 IDLER WHEEL (QH) HTH DAVID
tims31
posted on 16/12/12 at 10:59 AM Reply With Quote
Alpha,
Yes I also have the ribbed version, image below as requested.
Zetec idler wheel
Zetec idler wheel
loggyboy
posted on 16/12/12 at 01:15 PM Reply With Quote
Il have that if alfa doesnt want it!
Mistral Motorsport
tims31
posted on 20/12/12 at 12:21 PM Reply With Quote
Sorry loggyboy, posted to alpha now but do still have the smooth face pulley if thats any good?
loggyboy
posted on 20/12/12 at 12:32 PM Reply With Quote
Thanks, but need a ribbed one. I would expect 2 smooth pulleys (waterpump and idler) in sucession might end up with the belt slipping off.
Mistral Motorsport
tims31
posted on 20/12/12 at 02:54 PM Reply With Quote
Yep, not ideal. I will have a look to make sure but I think I only have two smooth face ones left
