Author: Subject: duratec arp torque settings
hootsno1
posted on 8/12/12 at 10:42 AM Reply With Quote
Hi all
Is there anyone out there that knows the correct torque settings for the arp bottom end bolts, and the arp flywheel bolts please
many thanks
Mark
[Edited on 8/12/12 by hootsno1]
If a little hammer won't fix it get a bigger hammer
big-vee-twin
posted on 8/12/12 at 03:42 PM Reply With Quote
The Duratec handbook recommends for the fly three steps to tighten
first to 50nm+-4nm
2nd 80+-4nm
3rd 112nm+-4nm
this is what I have used with my arp bolts
The instructions I have from ARP say 45 ft lb for con rod bolts
I tightened and released mine 3 times to ensure they had stretched properly
http://www.triangleltd.com
flak monkey
posted on 8/12/12 at 08:06 PM Reply With Quote
Follow the ARP specs not the haynes or duratec manual!
ARP bolt specs are all on their website, listed by thread size.
hootsno1
posted on 8/12/12 at 08:16 PM Reply With Quote
Thanks for your replays guys I have now found the correct settings.
Flack monkey do you still make the duratec fuel rails?
flak monkey
posted on 8/12/12 at 09:22 PM Reply With Quote
Yep, can still do fuel rails, no problem
