Author: Subject: Grinding wheels - Check em out!
gttztt
posted on 8/12/12 at 10:04 PM Reply With Quote
Evening all.
I've just converted an old grinding wheel to a polishing rig and found something disturbing.
When taking the wheel guards off, I found both grinding wheels were loose on the axle
and one even had a loose retaining nut.
I have been using the grinder (a very cheap one) for a couple of years without thinking about
any preventative maintenance. 5 mins to check out the security of the wheels now seems obvious
and will be something I will be doing from now on.
Are there any other obvious maintenance tasks I may be missing?
Stay safe.
Confused but excited.
posted on 8/12/12 at 10:12 PM Reply With Quote
Maintenance are what Friday afternoons are for.
When you are retired of course.
gttztt
posted on 8/12/12 at 10:18 PM Reply With Quote
I thought it was POETS day (although I haven't had one since 1989)
clanger
posted on 8/12/12 at 10:19 PM Reply With Quote
loop a bit of string through a wheel and give it a tap with the back of a screwdriver or somate hard plasticky, should have a nice ring to it?
dull thud and its cracked, bin it before it disintegrates
posted on 9/12/12 at 04:06 PM Reply With Quote
Check the work rests are adjusted correctly as well
