philfingers
posted on 17/12/12 at 12:15 PM |
Aldon 103fxy Dizzy for xflow on 40s with 234cam
as above, to fit a xflow with 234 cam and 40s. 103FXY or 103FXYS
The true home of cars born under the Sylva name - http://jpsc.org.uk/forum
STM Phoenix R1
Sold-Sylva Striker 1300xf, 40s etc
Sold-Sylva Phoenix, 1300xf, BVH, 234cam, 2xDCOE 40s, live axle - 'old school', rally car and a few bikes
steve m
posted on 17/12/12 at 03:40 PM |
Confused,
are you selling or wanted?
pekwah1
posted on 17/12/12 at 04:22 PM |
I''m guessing that being in the wanted section, he wants one steve!
philfingers
posted on 17/12/12 at 04:26 PM |
yes, wanted! you got my hopes up then when i saw a reply!
STM Phoenix R1
steve m
posted on 17/12/12 at 04:50 PM |
I had worked out the wanted bit!
but when viewed on the front page it does not say which catergry the thread was in,
pekwah1
posted on 17/12/12 at 05:37 PM |
you old timers... not very good with this technology thing are you!
Kevin
posted on 18/12/12 at 04:30 PM |
Aldon
Why Aldon, is it to replace an existing one?
philfingers
posted on 18/12/12 at 09:21 PM |
no, it's because it's fitted with a motorcraft on at the moment and I suspect the advance is wrong.
STM Phoenix R1
AndyGT
posted on 18/12/12 at 10:39 PM |
Could have one in the garage "floating around".
Let me check. How much are these things worth these days?
nothing is impossible
everything is possible
AndyGT
posted on 18/12/12 at 11:01 PM |
OK Checked it out. I THOUGHT it came out of the xflow I have but not so sure now... ...dizzy drive not the same. It is a blade type drive rather
than a geared drive on my xflow!!
The one I have (which I assumed was an Aldon) is a Lucas non-vacuum unit with the following numbers:
23 D4
41372 D
17 73
As far as I can work out. This is a cooper S or marina HC 1.3 unit but what I don't understand is that I have never had either of these cars.
But also listed as compatible with RS1800 Twin Cams and some other Ford Stuff...
I will post some piccies if you think it is useful...
PS Have Aldon used Lucas dizzy casts as their own in the past???
philfingers
posted on 18/12/12 at 11:26 PM |
thanks Andy, sounds like it's a Lucas but not a crossflow one. they were fitted to a lot of things with different drives. I'm sure if
could be made to fit but would need the advance modifying most likely.
They used genuine Lucas bodies with their own bits I think, or more likely a stock genuine one as a donor.
I missed on on ebay on sunday evening, so they're about, just finding one. Last one on here was £50, last one i bought for the phoenix 2 years
ago was £46.
I finally got the car running in the last hour, it's been lying idle for a good while, I suspect years! Seems to run ok, leaking rad and other
issues but in the main ok
STM Phoenix R1
Kevin
posted on 19/12/12 at 09:40 AM |
Accu-spark on ebay sells a new distributor and coil for £75 for crossflow, electronic ignition fitted.
philfingers
posted on 19/12/12 at 10:21 AM |
thanks kevin, yes I've seen them but I want one with the right advance for the cam, not just a stock one without vacuum
STM Phoenix R1
Kevin
posted on 19/12/12 at 10:34 AM |
I am sure that I have a Aldon 103fx down the garage. But do not think that it has vacuum on it.
philfingers
posted on 19/12/12 at 10:55 AM |
no it won't have, the spec for an 103FXY, and I need an FXY or FXYS is
"A non-vacuum distributor, which suits most tuned X/Flow engines using camshafts such as A2, BCF1, Piper 270,285, Kent 234,244 in conjunction
with side draught carburettors. N.B. A vacuum unit must not be used when an engine is fitted with side draught carburettors. "
STM Phoenix R1
