Author: Subject: Chain diff question
erwe
posted on 30/12/12 at 08:31 PM Reply With Quote
Chain diff question
I'm at the start of a new build, single seater BEC track car.
I stripped a Fiesta for donor parts, I try to build this one on a tight budget.
First thing is to use the diff (maybe replace it with a LSD type in the future).
I saw on other builds that the diff was supported in Pillow block bearings.
I need a bearing id of 38 mm but these or not available.
Someone knows a solution?
I already looked at the current (conical) bearings but this is not an option because they are open.
iank
posted on 30/12/12 at 08:46 PM Reply With Quote
Worth talking with http://www.westgarage.co.uk/ should be able to sort out something, they certainly work with some Fiesta diff's
Anonymous
big_wasa
posted on 30/12/12 at 08:57 PM Reply With Quote
35mm (1 1/4" ) would be a standard size. Find some one with a good lathe and turn the diff down.
[Edited on 30/12/12 by big_wasa]
snapper
posted on 31/12/12 at 07:03 AM Reply With Quote
Google industrial bearings
Also RS bearings
I know there are companies about that can supply pretty much any inner and outer size you want
It's just a matter of spending some time searching
I eat to survive
I drink to forget
minitici
posted on 31/12/12 at 09:23 AM Reply With Quote
The bearing spigots on your Fiesta differential are most likely 1-1/2" ID (38.1mm)
Sealed housed bearings (pillow blocks) are available as are sealed roller bearings.
If you use housed bearings you may struggle with keeping lubricant in the differential as it will leak out of the output shafts.
I make Aluminium Alloy bearing carriers with oil seal carriers to stop the oil/grease escaping.
Drop me a PM if you need more advice or any parts.
Doug.
russbost
posted on 31/12/12 at 10:59 AM Reply With Quote
I use standard 1 & 1/2" sealed roller bearings on the Furore with no extra sealing, we're running the diff in grease, we get no leakage other than a smear around the output shafts which is so slight as to be irrelevant, this is using a Toyota diff rather than Firesta, but would expect results to be similar
erwe
Stupid, after measuring again it seems to be 38,1 mm.
As you (from the island....) know better then me it is 1 1/2 inch....
So 8 pound each on the bay is el cheapo....
