Author: Subject: Anyone identify this Fuel pressure regulator?
mikey p
posted on 9/1/13 at 06:53 PM Reply With Quote
fuel pressure regulator
Received it in a job lot today....has no markings.
Interested to find out who makes them and what the spec is...
Mike
MakeEverything
posted on 9/1/13 at 07:29 PM Reply With Quote
A zinc plated one!
I had something similar on my old engine, which (i believe) was from a renault fuego or espace. It did raise the static fuel pressure, but i needed a vacuum reference and rising rate for the new install so binned it.
Mine had a large grub type screw, rather than a nut and bolt.
ETA: it didnt have a flange on it either, but yours may be just a standard item like mine was, to adjust static pressure.
[Edited on 9-1-13, by MakeEverything]
ETA:
OR
I could be wrong (See third item down)
Kindest Regards,
Richard.
mikey p
posted on 9/1/13 at 08:24 PM Reply With Quote
Originally posted by MakeEverything
A zinc plated one!
ETA:
OR
Thanks for the input! The MSD one looks quite similar.
I agree it looks like it is a OEM based FPR but has the JIC fittings and adjustability. It looks as if its all made in one also (not modified). looks like it could be a good one.....maybe...? haha
Will continue to search....
MakeEverything
posted on 9/1/13 at 08:27 PM Reply With Quote
A zinc plated one!
ETA:
OR
Wouldnt want to try it though....
Kindest Regards,
Richard.
Dusty
posted on 9/1/13 at 09:03 PM Reply With Quote
Looks a good quality bit of kit. Adjustable plus a vacuum reference. Try it, couple up a fuel pressure gauge and you should be able to get an idea of the specs.
mikey p
posted on 10/1/13 at 09:15 AM Reply With Quote
Looks like one of these....
Genuine HKS Adjustable Fuel Pressure Regulator with Earls fittings.
http://www.autoextreme.co.uk/hks-adjustable-pressure-regulator
just with a different bracket.
If it does as it says it could be ok.
2-5bar regulator.
Mike
