Author: Subject: Drive shaft lengths (Lobro)?
pigiron
posted on 21/1/13 at 02:27 PM Reply With Quote
Could anyone meassure a pair of Sierra rear bolt on 100mm Lobro type drive shafts please and tell me what model they come from.
I need some like this;
25 splines inner & outer, 47.4cm 7"
25 splines inner & outer, 51.5cm 7"
but for the life of me I cant find what Ford model the are off.
I have found reference to them on Seventh Heaven but no info on origin.
I am pulling my hair out here, please help
loggyboy
posted on 21/1/13 at 02:53 PM Reply With Quote
I would expect them to be all the same, ie fit any other petrol sierra with 100mm bolt on shafts. What do you need to check them for?
Mistral Motorsport
mcerd1
posted on 21/1/13 at 03:06 PM Reply With Quote
^^ there are 2 or 3 slightly different lengths used across the sierra/granada models - but I think it depends on age as much as the exact model
pigiron
posted on 21/1/13 at 04:32 PM Reply With Quote
Resolved!
The reason for my confusion is that I purchased a pair of brand new shafts from Ebay wich were listed as simply Sierra, when the arrived they were too short, leading me to question what my chassis requires.
I have just read the invoice, and spoken to the suplier, which I should have done days ago, and discovered they are specials for made for Wesfield (426mm&465mm).
Had they been listed as such it would have saved all the confusion.
mcerd1
posted on 22/1/13 at 07:58 AM Reply With Quote
they might be of use to someone here
or I think I've still got a pair of longer shafts (without joints) - I can look them out if you like ?
