Author: Subject: Hard Drive Failure
craig_007
posted on 26/1/13 at 08:06 PM Reply With Quote
Hard Drive Failure
My laptop has died on me (dell inspiron 1545) I can't get it to boot past a black screen.
Since then I have bought external reader and removed the hard drive from the laptop and fitted to that.
Now my other laptop read/recognizes the hard drive but when I open it up I can't find any of my files from my previous laptop !!
Doe's this sound like hard drive failure or am I missing something for finding my old files.
Any help appreciated.
gremlin1234
posted on 26/1/13 at 08:25 PM Reply With Quote
1) yes its failed,
2) dont write anything to it
3) if you have good backups use them
4) if you dont have good backups -.*, you may be able to recover files, but need specialist software for it.
ps might just be the boot record/ partition table, and booting windows from a cd and using fixmbr ( pre win7 )
PSpirine
posted on 26/1/13 at 09:30 PM Reply With Quote
It's about £500 to have data recovered off a failed harddrive. Stop using it immediately if you want any chance of the data being recoverable.
I've got two HDs which failed which had a lot of my photos on them. Can't justify £500 at the moment, but maybe one day! Pretty sure one failure was a controller rather than the disk itself so all data should still be intact.
pmc_3
posted on 26/1/13 at 10:01 PM Reply With Quote
By cant find any files do you mean you can't find your documents/pictures or you can't read anything on the drive?
jps
posted on 26/1/13 at 11:08 PM Reply With Quote
There is free ware software out there which you can use to retrieve data from hard drives that appear to have become empty. One is called get data back i think... A quick google should t turn up some options. No need to go anywhere near someone charging £500¡
Minicooper
posted on 26/1/13 at 11:54 PM Reply With Quote
I have used GetDataBack to recover a hard disk, it worked perfectly for me, it's not free though, that is under normal circumstances anyway
[Edited on 26/1/13 by Minicooper]
designer
posted on 27/1/13 at 11:03 AM Reply With Quote
At least Dick Turpin wore a mask when he robbed people!
johnemms
posted on 27/1/13 at 12:55 PM Reply With Quote
Look at the circuit board on the HDD
Note the board id numbers..
Do search on Ebay..
Replace controler board..
Take off files ..
Sell HDD.. on Ebay..
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
tegwin
posted on 27/1/13 at 02:28 PM Reply With Quote
£500?! Granted it was 5 years ago but the last time I had a catastrophic HDD failiure (head crashing) it cost me about £50 to send the disk away and have the contents sent back on dvds... google it
www.verticalhorizonsmedia.tv
craig_007
posted on 27/1/13 at 03:23 PM Reply With Quote
Thanks for the help chaps.
So is it likely to be the control board that is faulty ?
I've had a look for control boards but the one a require need to come from America.
PSpirine
posted on 27/1/13 at 03:31 PM Reply With Quote
Usually it's the controller that goes, which means all of your data is intact. However, if it stopped working due to a drop/shock or made funny mechanical noises, then it's probably a mechanical failure which is a bit worse!
craig_007
posted on 27/1/13 at 03:39 PM Reply With Quote
No drop or shock etc, when hard drive is connected to external reader the hard drive sounds at it should.
Can I just purchase another 160GB hard drive complete (suitable for my Dell) and use the control board from that ?
Can't seem to track a control board separately.
