Author: Subject: Sierra LSD; I.D. from a photo ?
pigiron
posted on 27/1/13 at 02:03 PM Reply With Quote
Is it possible to identify a Sierra type LSD (viscous) form a photo?
One often see's images on Ebay etc with the back cover removed and I wondered if there was any tell-tale signs to look for?
snapper
posted on 27/1/13 at 02:55 PM Reply With Quote
The one on the left is LSD
Not easy to tell from a photo
Turn input shaft both outputs turn the same way
I eat to survive
I drink to forget
mookaloid
posted on 27/1/13 at 04:16 PM Reply With Quote
this is true for limited slip and open diffs
Xtreme Kermit
posted on 27/1/13 at 04:41 PM Reply With Quote
But if you try to stop one of the output shafts:
The open diff will let you and spin the other faster.
The LSD will not let you stop one output shaft.
minitici
posted on 27/1/13 at 04:55 PM Reply With Quote
If the rear cover is off you will see a split line down the centre of the crown-wheel flange with the viscous LSD model.
The standard open diff has a one piece crown wheel mounting flange.
Previous thread Here
[Edited on 27/1/13 by minitici]
Dusty
posted on 27/1/13 at 05:57 PM Reply With Quote
This is in my car. 7" viscous LSD. Ford helpfully often write the ratio as shown.
[img] Ho ho. 3.62 written inside. Ford always did this. Handy!
[/img]
