New Topic New Reply
Author: Subject: whats this fixing called???
AndyW
posted on 27/1/13 at 04:32 PM Reply With Quote
Hi all,
I can think for the life of me what this fixing would be called. Its basically a flat square with a threaded stud coming off it. I have seen them before but cant remember a name to do a search.
I want them so i can put the flat part on the nosecone and through a bracket. The flat part then does not affect the bonnet fitment!
Any help appreciated.
ReMan
posted on 27/1/13 at 04:36 PM Reply With Quote
Not a car battery terminal bolt/screw?
Or a stud weld fixing?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
posted on 27/1/13 at 04:47 PM Reply With Quote
Big head??
ReMan
posted on 27/1/13 at 04:48 PM Reply With Quote
http://www.shop4fasteners.co.uk/acatalog/Mild_Steel_Threaded_Stud_Bonding_Fasteners_15mm_Square.asp
Antother possibility , Racking bolts?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
ReMan
Big head??
No I was just trying to be helpful
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
loggyboy
posted on 27/1/13 at 04:55 PM Reply With Quote
Square head bolt?!
Mistral Motorsport
AndyW
posted on 27/1/13 at 05:05 PM Reply With Quote
Thats the type of thing
Thank you!!
posted on 27/1/13 at 07:34 PM Reply With Quote
Try Googling Big head bonding fasteners
[Edited on 27/1/13 by rusty nuts]
hootsno1
posted on 27/1/13 at 07:54 PM Reply With Quote
I used a m10 bolt and ground the head down till its about 1mm thick then ground the gel coat down to get the head of the bolt to sit flush and glued it in place
If a little hammer won't fix it get a bigger hammer
New Topic New Reply
