Author: Subject: Silvertop head on blacktop poss?
pigiron
posted on 6/2/13 at 10:47 PM Reply With Quote
Is it possible to fit a 2.0 Zetec silvertop head on a 2.0 blacktop block?
austin man
posted on 6/2/13 at 10:53 PM Reply With Quote
what are you hoping to gain from this
pigiron
posted on 6/2/13 at 11:09 PM Reply With Quote
I have a hydraulic big ported and valve head with Newman PH4 cams and a worn out bottom end. There are new blacktop short motors available at silly money, it would make sense if I could marry the two.
Ha, just noticed what I have written above, yes my own bottom end could do with a rebuild aswell.
posted on 6/2/13 at 11:18 PM Reply With Quote
Nope, creates problems with the cam belt.
No point when you can pick up engines for next to nowt.
usher179
posted on 6/2/13 at 11:28 PM Reply With Quote
the silvertop and blacktop head and block can't be fitted to each other with out work, as said in a previous post it creates problems with the cam belts routing arount the water pump......the only way round i have tried it is the blacktop head with solid lifters fitted to the silvertop bottom end.
http://www.ushermotorsport.co.uk.
pigiron
posted on 7/2/13 at 08:47 AM Reply With Quote
Many thanks, good info.
