posted on 13/2/13 at 02:54 PM |
Heating Programable TRVs Pegler Terrier itemp I30
Up grading the central heating controls I just fitted a programmable roomstat and i am now looking at the other rooms anybody tried
Pegler Terrier itemp I30 programable radiator valves -- they look good value particularly as they can be remotely programmed by either a
remote or from a PC.
posted on 13/2/13 at 07:56 PM |
Never tried one but always fancied having one to turn off the main lounge radiator overnight.
coyoteboy
posted on 13/2/13 at 08:00 PM |
Don't forget that unless you keep all doors shut you'll be seeing very little gain from having rad stats set lower in some rooms or
overnight as the remaining rads try their hardest to heat the whole house.
MkIndy7
posted on 13/2/13 at 08:48 PM |
I'd have thought there more of a commercial (or retrofit) thing really, where different offices work different times of the day etc and it stops
people meddling with them where they didn't have proper controls installed in the first place or maybe its Cheeper than installing a full
control system.
Higher initial investment than normal TRV's and there will be an ongoing cost with replacing the batteries etc I can't see them making
that much difference in a domestic system but I'm happy to be proved wrong lol
posted on 13/2/13 at 11:07 PM |
I've only read about them but a lot of comments are about how noisy they are in operation.
posted on 14/2/13 at 07:59 AM |
My main reason for fitting them is by delaying the start of heating to some rooms they would give a quicker warm up in the mornings to the rooms
used in the early part of the morning.
Noise isn't going to be problem as they would be fitted at least initially in places like the down stairs loo, both home offices, kitchen.
posted on 14/2/13 at 12:27 PM |
I now have fitted one to the downstairs loo, fitting was easy programming was not so easy, instructions as clear as mud and don't
detail all the functions however it is now setup and working. Not too noisy in operation. If it works as expected over few weeks i will fit them
to more rooms but a computer interface will be a must have.
