Author: Subject: what gasket? - raceline sump
mkeats02
posted on 22/2/13 at 08:32 PM Reply With Quote
Hi
What gasket do I need for my race line sump and zetec blacktop?
Mike
This Monkey's gone to Heaven
Thruth does not exist, it is only Human Opinion
big-vee-twin
posted on 22/2/13 at 09:08 PM Reply With Quote
Loctite RTV 598 sealant
http://www.triangleltd.com
jossey
posted on 22/2/13 at 09:21 PM Reply With Quote
As above.
David Johnson
Dusty
posted on 22/2/13 at 09:48 PM Reply With Quote
Raceline sump uses the old style silvertop standard sump gasket. Same style 'rubber' sausage as the cam cover gasket and not the blacktop upper sump gasket. FIESTA ESCORT MONDEO 1.6 1.8 2.0 ZETEC SUMP GASKET | eBay
SUMP GASKET FORD MONDEO 2 1998-2000 | eBay
Xtreme Kermit
posted on 22/2/13 at 09:54 PM Reply With Quote
I would advise getting a pucker ford one. The looky likey one I got was not a good fit. Not floppy enough
mkeats02
posted on 22/2/13 at 10:43 PM Reply With Quote
Cheers guys
Paul Turner
posted on 23/2/13 at 08:35 AM Reply With Quote
As posted above the Raceline sump uses the standard Silvertop sump gasket. You do need a small bit of sealant at the 4 points where the front and rear covers and gasket cross.
Do not use a pattern gasket, they leak and turn to Gorilla snot. Buy a genuine Ford one, only cost pence more.
Same applies to cam cover gaskets.
