Author: Subject: Cant believe i did it - battery wiring wrong way round
Norfolkluegojnr
posted on 26/2/13 at 09:18 PM Reply With Quote
Right! One of those days you just shouldn't have bothered......
Bought a new battery for the mini, and attached the terminals. just as i'm attaching the earth, notice loads of smoke. Quickly disconnect and see its coming from the alternator wiring - i've only gone and connected the terminals the wrong way round
So what damage have I done? I presume the alternator is shot, what else could I have melted? No other obvious damage other than the wiring the the alt which is nicely melted.
Wiring is standard apart from megajolt (please tell me thats not fried!) which is on a switched live.
Also - anyone know the correct wiring for a three pin alternator in a mini with the wing mounted solenoid? as the wires are melted, I can't decifer colour etc.
Frustrated with my stupidity!!!!!! Definitely hate cars today.
perksy
posted on 26/2/13 at 09:37 PM Reply With Quote
Probably the Rectifier in the Alternator for start, plus some wiring by the sounds of it
If you've now connected the battery correctly, Have you now got an ignition warning light on all the time with the ignition switched off ?
daniel mason
posted on 26/2/13 at 09:38 PM Reply With Quote
YOUR PRIDE IS NOW RUINED!
worse things happen at sea mate, dont worry about it!
Norfolkluegojnr
posted on 26/2/13 at 09:39 PM Reply With Quote
no, no lights at all.
the alt is disconnected though, as the wiring is totally shot.
There are three wires on the alt, one is the warning lamp - that seems fine - plus two others that go to the starter solenoid at the same terminal?
I'm confused? (not for the first time today clearly)
Norfolkluegojnr
posted on 26/2/13 at 09:42 PM Reply With Quote
New this would start
I deserve all punishment and ridicule due. Sadly, not the most stupid thing ive done though.
RIE
posted on 26/2/13 at 10:06 PM Reply With Quote
I'm not going to point and laugh, because I know I will do the same (or probably something even worse). And I probably already have done, just blocked it out of my memory.
Norfolkluegojnr
posted on 4/3/13 at 09:54 AM Reply With Quote
Just to round this one off and for future numptys....
Rewired the alternator and all appears to be well. Charging light went straight out and I'm getting 14v at the battery. It appears no other damage was caused, but I did spend a long time checking all wiring!
So all in all fairly minor in the end.
Jimfin
posted on 4/3/13 at 09:30 PM Reply With Quote
Not a Minor, just a Mini problem then
