Author: Subject: LED brake lights stopped working
spoonana
posted on 10/3/13 at 01:28 PM Reply With Quote
I have LED lights for my Locost which worked back in the summer
The rear lights and brake lights are all in one. The rear lights work but the brake lights don't.
Last time we had the car out they all worked fine.
I've checked that all the connections on the brake cylinder, dash and lamps are okay.
What am I missing??
matt_gsxr
posted on 10/3/13 at 01:32 PM Reply With Quote
do you use a brake pressure switch to activate the light? these have a poor reputation for reliability.
spoonana
posted on 10/3/13 at 01:36 PM Reply With Quote
There are 2 connections on the copper pipes. How can I check?
Ben_Copeland
posted on 10/3/13 at 01:39 PM Reply With Quote
Short the wires together and see if the lights come one.
Looks similar to this :
http://www.demon-tweeks.co.uk/Product.do?method=view&n=1720&p=165784&c=215&utm_source=Google&utm_medium=Base&utm_campaign=Brak e%20Tools%20&%20Accessories&gclid=CKekgfei8rUCFUfMtAod5gMAug
[Edited on 10/3/13 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
spoonana
posted on 10/3/13 at 02:34 PM Reply With Quote
solved
Shorted the wires across and yes the brake lights came on
Will order one express delivery as trackday at Castle Coombe on Friday
Many thanks Ben
matt_gsxr
posted on 10/3/13 at 06:01 PM Reply With Quote
Originally posted by spoonana
Many thanks Ben
no problem
posted on 10/3/13 at 06:29 PM Reply With Quote
To be 100% Bridge the two wires together ---- not short to earth
Ben_Copeland
posted on 10/3/13 at 07:00 PM Reply With Quote
That's what he did
Ben
spoonana
posted on 12/3/13 at 06:06 PM Reply With Quote
not solved
Hi folks thought I was sorted when Ii connected the 2 wires and the brake lights come on.
Ordered a replacement hydraulic brake light switch which I have just fitted and it still doesn't work!!
Any more thoughts?
loggyboy
posted on 12/3/13 at 06:14 PM Reply With Quote
You will need to ensure theres no air in the system, if you let air in when u replaced the switch it will need bleeding.
Mistral Motorsport
Ben_Copeland
posted on 12/3/13 at 07:39 PM Reply With Quote
Also best to have switch pointing down so air can't get trapped.
Wires down.
Ben
