Author: Subject: Stubborn diff refil bolt
cerbera
posted on 18/3/13 at 11:32 AM Reply With Quote
The refil bolt on my diff is being an utter %*&! and doesn't want to come out. Is this usual or am I unlucky?
I've given the bolt a thorough dowsing with WD40 with no joy.
What next?
posted on 18/3/13 at 11:43 AM Reply With Quote
I don't think it's that unusual. On mine I had to use a long bar and a big hammer. WD40 isn't a very good penetrating oil- it's not terrible but it's not the best. I'd use some proper penetrating oil and give it a goodly time to work. If that doesn't work get out the blowtorch and heat it up a few times to break the stiction.
Charlie_Zetec
posted on 18/3/13 at 11:44 AM Reply With Quote
I'd give it a shout with some PlusGas to see if that helps - bit more hardcore than WD40.
Failing that, I'd consider putting an impact driver on it, and give it a thump. It's a big enough bolt, so that might jolt it free.
As a last resort I'd maybe try an impact gun if you have one....
big-vee-twin
posted on 18/3/13 at 11:48 AM Reply With Quote
Mine came out with a big hammer and a chisel, and plus gas.
Then fitted a replacement drain plug
http://www.triangleltd.com
chris_harris_
posted on 18/3/13 at 12:37 PM Reply With Quote
Mine was a total swine to get out too, i also resortd to hammer and cold chisel.
Regards Chris
adithorp
posted on 18/3/13 at 01:19 PM Reply With Quote
They always were a bugger to get out on Sierras. Quite common to round out the allen key trying as well. Heat and shock (hammer) is the best answer.
http://jpsc.org.uk/forum/
cerbera
posted on 18/3/13 at 01:40 PM Reply With Quote
Thanks for the replies guys. Not too keen in applying a naked flame to it because of the close proximity of the fuel tank. I'll try the plus gas and see how I get on from there.
mookaloid
posted on 18/3/13 at 01:46 PM Reply With Quote
Done several - all were stuck - all shifted very quickly with a couple of smacks from the hammer and cold chisel
Mikef
posted on 18/3/13 at 02:00 PM Reply With Quote
have always used some heat, not direct flame , but a heat gun , might take a bit of time but generally works.
Canada EH!
posted on 18/3/13 at 02:10 PM Reply With Quote
That would never have been a problem with the cars of the 50's.
That plug was taken out every 5000 miles to check how much lube had been lost since the last inspection.
See modern cars are better, we're just a little less thorough.
Davey D
posted on 18/3/13 at 03:03 PM Reply With Quote
I ended up welding a normal hex bolt head onto the original bolt head after I rounded it out. The heat from the welding, and the better grip I could get on a bolt head managed to break it free.
dave r
posted on 18/3/13 at 06:01 PM Reply With Quote
i welded a nut on mine too... came out easy then
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
jacko
posted on 18/3/13 at 08:27 PM Reply With Quote
I cut a slot across the plug with a cutting disc and used a piece of flat bar to remove the plug +the heat of cutting the slot helped to release it
Jacko
cerbera
posted on 23/3/13 at 09:03 AM Reply With Quote
Got the barsteward out at last
