Author: Subject: Hayabusa tightening torques ?
Relph
posted on 19/3/13 at 05:08 PM Reply With Quote
Hi, I'm fitting a powertec dry sump with baffle plate to my hayabusa engine. Does anyone know the torque settings for the 3 crankcase bolts that hold the baffle plate in and the settings for the sump bolts ?
motorcycle_mayhem
posted on 19/3/13 at 06:03 PM Reply With Quote
Various crankcase bolts, unsure which are in use for your baffle.
Sump pan bolts on a std Hayabusa sump pan are 10 Nm, 1.0 kgf-m or 7.0 lb-ft as are the oil strainer/pick-up pipe pair.
