Author: Subject: Fluoro lined silicone hose
Dooey99
posted on 24/3/13 at 09:34 PM Reply With Quote
do i really need to use fluoro lined silicone hose to go from my bike carbs to inlet manifold?
i think i probably should but its so expensive!!!
i need 42mm I/D does anyone have 160mm spare i can buy?
or would anyone be interested in buying some off me if i bought a full 1000mm length?
id only charge you cost price plus a couple of £s for postage
its just im not going to need a meter i only need 16cm or 4x40mm and it costs about £40 for a meter
Less weight more speed, more power more speed
If in doubt, give it a clout
computid
posted on 24/3/13 at 09:36 PM Reply With Quote
Yes, yes you do.
Dooey99
posted on 24/3/13 at 09:43 PM Reply With Quote
yeah thats what i think aswell but i was sort of more directing it at anybody else that might want to buy some off me... its not really locost stuff!
paulf
posted on 24/3/13 at 09:45 PM Reply With Quote
No you dont have to use fluoro lined hose, plain silicon degrades rapidly. I used black rubber water hose which is about £8 metre and have not replaced it in 5 years so far.
Paul
Andybarbet
posted on 24/3/13 at 09:48 PM Reply With Quote
I will measure my throttle bodies & let you know, if its the same size then i would buy 4 short stubbs off you.
I have standard silicone to go on them at the moment but the the lined stuff would be better.
posted on 24/3/13 at 10:44 PM Reply With Quote
Silicone hose is also a lot more likely to slip off than rubber,
maccavvy
posted on 25/3/13 at 07:53 AM Reply With Quote
plenty of people selling short lengths with clips on ebay at a good price
Understeer , when the front hits a wall
Oversteer, when the back hits a wall
Horsepower ,how fast you hit the wall
Torque ,how far you take the wall with you
renetom
posted on 25/3/13 at 08:08 AM Reply With Quote
Hi
something like this do the job ?.
http://www.cbsonline.co.uk/product/50-45mm_ID_Reducer_HRED50
Good luck
René
FASTdan
posted on 25/3/13 at 08:24 AM Reply With Quote
My 40mm kits listed on ebay will easily stretch to 42mm - and with a bit of stretch and the narrow hose clips they give a very firm grip.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
posted on 25/3/13 at 03:02 PM Reply With Quote
If you can find some of a suitable diamater, fuel proof rubber hoses are a much better solution than silicone. It grips better onto metal and is tougher and is less easily damaged. If going for silicone then fluoro lined is the one to go for as normal stuff isn't fuel resistant (and even fluoro lined hose is not usually rated for continuous contact with petrol).
FASTdan
posted on 25/3/13 at 03:34 PM Reply With Quote
Correctly sized fluoro lined silicone coupled with correctly sized hose clips does not slip off......instances of which are a result of poorly made misaligned manifolds and/or badly sized silicone/clip combinations.
A few points - sorry if this is stating the obvious but unfortunately silicone mountings often get a bad rep - most of which is down to skewed manifolds and long buldging baggy hoses used to overcome alignment.....
The manifold tubes need to be parallel and spaced to match the carbs - tubes that are not parallel with the carbs just try to pull the hoses off the carb body.
9mm wide bands should be used on the carb side. 12mm wide bands are too big for the carb end and simply try to squeeze the hose off the chamfered carb body.
Hose size should be snug or stretched ideally. Compressing down by 1-2mm can work but avoid if possible.
'Free length' of the hose (ie the bit between manifold and carb) should be kept to a minimum. Our kits are 50mm hose lengths which offer a small amount of flexibility for trimming etc should it be desired.
Dooey99
posted on 25/3/13 at 04:47 PM Reply With Quote
fastdan, have you got an ebay item number for your kits?
thanks
