Author: Subject: Zetec or st170 tentioner ? Again ..
monck
posted on 27/3/13 at 03:11 PM Reply With Quote
Some may remember my last post regarding cam belt pulleys .
The two pulleys are different i have 2 used ones a zetec one (Made In Germany) and the st170 one (Made In Canada)
So as there different i assume i get a st170 one correct for the engine.
I then noticed Silky16v's st170 motor on here is fitted with a zetec tentioner/pulley shown in below thread so it works (I have also seen st170's with a zetec pulley )
http://www.locostbuilders.co.uk/viewthread.php?tid=175158&page=1
And here is a ST170 original one fitted in below thread
http://www.turbosport.co.uk/showthread.php?t=137130
Is this just a case of different designs ? the Canada one seems to have a few more bits and is 11g heavier .. But the zetecs made in Germany so i assume the quality's better no ? Both seem prone to failing if you Google it just want to get the better of the two ..
Zetec ones £29.21 including vat from burton power the st170 one is £60 odd plus vat from ford parts no one else seems to have them . Burton power told me they had no other tentioner listed for the st170 .
Ryan
[Edited on 27/3/13 by monck]
monck
posted on 27/3/13 at 03:22 PM Reply With Quote
rhinopower
posted on 27/3/13 at 03:56 PM Reply With Quote
All pulleys are the same for blacktop based zetecs. I've had both an st170 and regular blacktop. This pully is what you need, exactly the same as a genuine ford item but without the price tag.
http://www.eurocarparts.com/ecp/c/Ford_Focus_2.0_2001/p/car-parts/engine-parts/belts-chains-and-tensioners/tensioners-idlers-and-dampers/?326590190&am p;1&3afb8ddad6e2cfa7e15e0890870b5fb19f59aab9&000578
emwmarine
I may be being dense but I can't see the difference between the tensioners? Both look like mine?
Building a Dax Rush.
