pointy
| posted on 28/3/13 at 07:08 AM |
NOW BREAKING LOCOST RACE CAR
Due to a rethink 750MC Locost Race Car now being broken: (See Locost race car for sale)
See below for list. Car is still whole currently but will be breaking over the Easter Break. If anyone interested in parts U2U me and I will send
pictures.
Stuart Taylor Roll Cage and home built chassis (with aluminium panels fitted) has gold brake pedal box & reservoirs fitted £400
Engine (Build Cost £1000) built to locost regs Blueprinted +60 pistons £850.00 -SOLD
Brand new 32/36 DGAV CARB Fitted to above engine and run for 10 minutes only £150 - SOLD
K & N Air Filter £20.00 - SOLD
GT Gearbox £50.00- SOLD
Quick rack steering (Brand new) £90.00
Avo Shocks (second hand) £80.00
8 x Laser Capri Alloy Wheels with scrubbed regulation tyres (Yokohama 539s) £100 per set of 4
Cortina Brake Discs (New) £20.00 Pair
Remanufactured Cortina Calipers £60.00
Polo Radiator (second hand) £15.00
Tony Laws 4 to 1 Exhaust System including can £100.00 - SOLD
17 litre Aluminium Fuel Tank £40.00 - SOLD
Mountney Removable Steering Wheel £15.00
White rear arches £50 pair
White Front arches including stays £40.00
Wish bones top and bottom (1 front top needs slight repair) £50.00 2 pairs.
Rear axle including brake assy and shoes £50.00
4.1 Diff £60.00
Trailing arms £20.00
Panard Rod £15.00
Propshaft lightened, balanced and cut to correct size for attaching to 4 speed box £80.00 (receipt available)- SOLD
Rev counter £20.00
Spring (2.25 od) to fit Avos 2 x 350 LB and 2 150LB £25.00 pair
Cortina Uprights (complete with new wheel bearings) £60.00 Pair
Pair of half shafts £40.00
Also available:
4 Speed Gearbox (untried or tested) £30.00
711M 6015 1.3 Engine standard with no ancillaries (bought as a spare- turns freely) £75.00
All parts will be heavy so collection better, however willing to courier or post at buyer expense.
Other items - bonnet, nose cone etc will be added later.
[Edited on 28/3/13 by pointy]
[Edited on 29/3/13 by pointy]
Disgruntled karter
| posted on 28/3/13 at 07:35 AM |
Hi interested in your engine gear box and prop and exhaust where in the country are you
pointy
| posted on 28/3/13 at 07:49 AM |
Based in Dereham, Norfolk.
clanger
| posted on 28/3/13 at 08:02 AM |
u2u re quickrack
sickbag
| posted on 28/3/13 at 08:17 AM |
Interedted in the fuel tank - have you the dimensions? And would need it to be posted. All costs met.
Finally back on the job!
pointy
| posted on 28/3/13 at 08:42 AM |
Hi, fuel tank dimensions are:
Width - 23cm
Length -52.5cm
Depth - 17.5cm
Not sure how much postage would cost yet, but will look into it.
sickbag
| posted on 28/3/13 at 08:50 AM |
Thanks Andy,
I'll have the tank thank you very much
Let me know the postage, etc, and payment method.
Regards,
Tony.
Benzo
| posted on 28/3/13 at 11:18 AM |
PM sent regarding the steering rack.
snippy
| posted on 29/3/13 at 12:31 AM |
U2U sent re Rev Counter
thefreak
| posted on 29/3/13 at 08:12 PM |
Have you got a transponder? If so I'd be interested.
pointy
| posted on 29/3/13 at 09:25 PM |
No transponder as keeping this for another race car.
pointy
| posted on 30/3/13 at 02:12 PM |
Update on Locost Spares Available
Update on whats still available. U2U for more details.
Stuart Taylor Roll Cage and home built chassis (with aluminium panels fitted) £400
4 Avo Shocks (second hand) (1 shock needs minor refurb no clicks ) £80.00
Spring (2.25 od) to fit Avos 2 x 350 LB and 2 x 150LB £20.00 pair
Refurbished Cortina Calipers £60.00
White Front arches including stays £50.00
Wish bones top and bottom (1 front top needs slight repair) £50.00 for all four
Rear axle including brake assembly and shoes £50.00
Panard Rod £15.00
4 Speed Ford Gearbox (untried or tested) £30.00
711M 6015 1.3 Ford Crossflow Engine standard with no ancillaries (bought as a spare- turns freely) £75.00
pointy
| posted on 30/3/13 at 04:00 PM |
ALL SOLD!!
Ladies/Gents....Everything now sold!!
