Author: Subject: Supercharged Phoenix - Abbeville - Flames
jeffw
posted on 29/3/13 at 09:10 PM Reply With Quote
Flames out of my car at Abbeville today
Ben_Copeland
posted on 29/3/13 at 09:24 PM Reply With Quote
Nice mate It'll keep that tyre up to temperature too
Ben
Locost Map on Google Maps
Enter Your Details Here
Andy S
posted on 29/3/13 at 09:29 PM Reply With Quote
Nice bit of footage to also show the amount of tyre deflection that goes on.
Proby
posted on 29/3/13 at 09:53 PM Reply With Quote
Nice flames!
Visit GraphicMonster
jeffw
posted on 29/3/13 at 10:12 PM Reply With Quote
Backward GoPro shot with my Son onboard the Phoenix.
Dingz
posted on 29/3/13 at 11:11 PM Reply With Quote
Have you got a panhard rod? axle seems to move quite a bit.
went on and on.
jeffw
posted on 30/3/13 at 07:04 AM Reply With Quote
There is a panhard. You are not the first to mention this but I think it is a combination of low pressure high profile tyres, some lateral axle movement (which is to be expected), axle 'roll' under cornering as the suspension compresses and the unusual view. As the prop flange doesn't hit the tunnel either side with the adjustable Panhard rod and you don't feel it in the car I think it is normal.
matt_gsxr
posted on 30/3/13 at 09:32 AM Reply With Quote
I am just trying to understand the mechanism of this (from a mapping perspective).
It looks to me that it is only igniting after the 'tail' pipe and there are no pops (except the ones that blow out the flames when you come back onto the power), so does that mean that what is coming out is so overloaded with fuel that it doesn't burn in the exhaust?
Is this all legacy fuel that has accumulated in the silencer when at high power? You get fewer flames at the beginning so maybe that makes sense.
Any thoughts?
Matt
striker-4age
posted on 30/3/13 at 10:22 AM Reply With Quote
Jeff what gearbox do u run ?
jeffw
posted on 30/3/13 at 10:45 AM Reply With Quote
More standard view with Andy Elcomb show boating in the car.
And the track
The car has a ceramic coated exhaust and the exhaust gases are way hotter than you would normally get (the heat has to go somewhere). When the car was originally mapped it pop'ed and banged on overrun which, while amusing for 10 mins, gets very wearing so Atspeed put a little fuel into the map at lift off to get round the ignition cut noises....hence what you see on overrun. The exhaust obviously gets hotter during the run and ignites the small amount of fuel that is put through the system.
[Edited on 30/3/13 by jeffw]
jeffw
posted on 30/3/13 at 10:57 AM Reply With Quote
The car has a BGH Type 9 E8 with special fairy dust. It is the top spec box BGH can make currently and is marginal for the engine. If I had the money I'd be looking at a Quaife or Elite 6 speed sequential.
