Author: Subject: R1 08 Tachometer wire
Kev99
posted on 13/4/13 at 11:08 AM Reply With Quote
Trying to work out which wire it is out of the ecu or clock for the digi dash anyone know?
Kev................
TimC
posted on 13/4/13 at 12:33 PM Reply With Quote
Kev,
Once I get home I'll be able to tell you as my loom is all labelled up there.
It'll be late tonight if nobody replies first.
TC
Kev99
posted on 14/4/13 at 06:13 AM Reply With Quote
No one else replied and still cant work it out was thinking its the yellow/black wire from ecu to clocks
renetom
posted on 14/4/13 at 07:00 AM Reply With Quote
its yellow & black on our 2001 carbed R1
We still had a problem with the rev counter bouncing up & down.
Purchased one of those magic boxes which supposedly fools the ecu into thinking the exup motor is there, was expensive & didnt work, stripped the pulley off the exup motor
Cut off the shaft & fitted it into engine bay
wired it up & hey presto everything worked.
It only a tiny motor & weighs next to nothing & you can't hear it working.
good luck
[Edited on 14/4/13 by renetom]
TimC
posted on 14/4/13 at 07:36 AM Reply With Quote
On it now....
TimC
posted on 14/4/13 at 07:41 AM Reply With Quote
Yes, yellow and black.
Kev99
posted on 14/4/13 at 12:08 PM Reply With Quote
thanks all will go and look now
