Author: Subject: Pinto to ST170
floaty
posted on 16/4/13 at 08:38 AM Reply With Quote
Pinto to ST170
What other parts do I need to change ie clutch, pressure plate, spigot bearing, clutch fork thrust bearing. Cheers Floaty
monck
posted on 16/4/13 at 09:57 AM Reply With Quote
Hi mate its a fancy zetec engine so exactly the same
http://www.toyne.org.uk/kc-mods-engine.html
That site should be helpful
Daddylonglegs
posted on 16/4/13 at 05:34 PM Reply With Quote
But isn't that a Zetec Phase 2 to a Zetec Phase 3 conversion?
I thought he wanted Pinto to Zetec?
monck
posted on 16/4/13 at 06:51 PM Reply With Quote
Very true Floaty , It does though tell you what is required regarding clutch ect
i personally used
lightened zetec flywheel re-drilled for a pinto clutch
zetec to type 9 spigot bearing from Burton power
QH pinto clutch and thrust bearing
Zetec bell-housing
Some people use a zetec clutch but cant tell you what that would require ..
I would replace the clutch while your at it for the cost though rather than reuse pinto one..
[Edited on 16/4/13 by monck]
