Author: Subject: It's all gone a bit crunchy at the rear end
NeilP
posted on 21/4/13 at 06:18 PM Reply With Quote
A fairly impressive grinding noise coming from behind me whilst coming back home from a blat. Not had a look at it yet but either wheel bearing utterly shot, or CV joint (no knocking though) or my very second hand LSD. Suspect the latter as the magnetic plug had a decent amount of swarf on it last time I checked levels. I have a spare open diff so guess what I'll be doing next Sat morning!
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
jacko
posted on 21/4/13 at 06:31 PM Reply With Quote
Snap
I have the same thing on my car it's the second diff know and thinking of fitting a 7.5" diff
Jacko
posted on 21/4/13 at 06:52 PM Reply With Quote
Check the propshaft coupling bolts for tightness first.
NeilP
posted on 21/4/13 at 07:11 PM Reply With Quote
Thanks BT - I'll start at the wheels and work in towards the diff - it all needs a spring clean anyway...
posted on 21/4/13 at 07:59 PM Reply With Quote
Hope you get it done for Stoneleigh
NeilP
posted on 28/4/13 at 02:11 PM Reply With Quote
Quick update - Diff, prop, half shafts, cv joints and wheel bearing all fine. Was the offside caliper a bit jammed up so it had trashed the inner pad and cooked itself up a bit. Ordered new pads in so will be back on the road for Stoneleigh
