Author: Subject: In Tank pump connection
DannyC
posted on 24/4/13 at 10:23 PM Reply With Quote
My replacement pump has a 8mm output pipe, whereas the original was a rubber 'female' seal which pushed over the steel pipe that's connected to the tank mounting plate (if that makes any sense!).
I am able to overcome this by joining the output pipe to the steel pipe using a short length of fuel hose.
So my question, is it OK to use fuel hose, and connectors inside the tank?
I believe it should be OK, but confirmation would be reassuring.
Many thanks
Danny
posted on 24/4/13 at 10:28 PM Reply With Quote
You need pucka in tank fuel hose, normal stuff drops to bits very quickly!
DannyC
posted on 25/4/13 at 08:52 AM Reply With Quote
Thanks Coozer, although not the answer I wanted!
In tank hose available in 1m lenghts, no doubt!
Danny
dave r
posted on 25/4/13 at 09:07 AM Reply With Quote
proper stuff is expensive though
lined inside and outside
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
DannyC
posted on 25/4/13 at 12:15 PM Reply With Quote
I only need 2"
As a temporary measure, how long would ordinary fuel hose last?
posted on 25/4/13 at 12:40 PM Reply With Quote
Not long, it falls to pieces..
Are you going to Stoneleigh?
DannyC
posted on 25/4/13 at 12:58 PM Reply With Quote
No, I can not make it this year.
I have just seen that Merlin motorsport sell it. I need some other bits as well, so will probably pop over.
Thanks for the advice.
Danny
posted on 25/4/13 at 01:07 PM Reply With Quote
I tried Merlin but none in stock, they took my money then told me....
Got mine off fuelpumpsonline but they not showing any stock either!
dave r
posted on 25/4/13 at 01:40 PM Reply With Quote
what diameter do you need ?
DannyC
posted on 25/4/13 at 02:44 PM Reply With Quote
I/D required is 8mm (5/16)
dave r
posted on 25/4/13 at 02:50 PM Reply With Quote
http://www.gatesunitta.com/en/gates-m-pi-fuel-injection-hose-4219-series
i have some of that....in 8mm... cost me an arm and a leg though as was special order from the states, i thought i was getting 10m for the price, but only 5m appeared
[Edited on 25/4/13 by dave r]
