Author: Subject: 22 hole
theconrodkid
posted on 1/5/13 at 08:26 PM Reply With Quote
22 hole
anyone on here have the ability to make 2"/51 mm holes in steel plate 4mm or thicker?,i need 2 plates with the hole in the middle,plates aprox 5" X 3"
who cares who wins
pass the pork pies
theprisioner
posted on 1/5/13 at 08:36 PM Reply With Quote
Easiest way is a Mag drill with appropriate cutter. I have the Mag Drill but not a 51mm cutter which is very expensive mine stop at 48mm and I am a long way from you I suspect.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
bashracing
dont know where you're based but try these
http://www.daysteel.co.uk/
big_wasa
posted on 1/5/13 at 08:52 PM Reply With Quote
Is this for your decat pipe ?
eBay Item
owelly
posted on 1/5/13 at 09:45 PM Reply With Quote
I cut a few 2" holes in 6mm steel with a holesaw. I cut a hole through some plywood first and clamped it to the steel to stop it from wandering oversize and the wood also helped contain a puddle of cutting fluid. Nice and slow with good quality holesaw.
http://www.ppcmag.co.uk
red22
posted on 1/5/13 at 10:07 PM Reply With Quote
Why not try a local engineering firm or someone helpful on here with a lathe, a 4 jaw chuck and a boring bar.
madteg
posted on 2/5/13 at 05:43 AM Reply With Quote
Just use a good hole saw you be surprised how easy it is, lots of lube and as slow as the drill will go.
dave r
supprised no-ones has mentioned water cut and andy yet.........
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
theconrodkid
posted on 2/5/13 at 06:07 AM Reply With Quote
cheers for the replies peeps,looks like a holesaw jobbie,any recomendations on a brand/suplier ?
who cares who wins
pass the pork pies
owelly
posted on 2/5/13 at 06:15 AM Reply With Quote
Starrett! I have some of the cheapy ones and they do the job but the Starrett ones have been doing the job for the past 15 years!
neilp1
posted on 2/5/13 at 07:20 AM Reply With Quote
I'll second that for starrett. We regularly use these hole saws to cut anywhere from 3mm to 25mm steel. Just remember that you need an A2 arbor for 51mm.
http://www.screwfix.com/p/starrett-a2-arbor/86678
[Edited on 2/5/13 by neilp1]
tonym
posted on 2/5/13 at 08:22 AM Reply With Quote
If it is only to weld in an exhaust tube a plasma cutter will do the job.
MakeEverything
posted on 2/5/13 at 09:11 AM Reply With Quote
Ditto. Use anything else that size, and you risk it shattering, going blunt, or giving you a 55mm hole!
Get a quality cutter. The cheap ones are cheap for a reason.
Kindest Regards,
Richard.
dave107
posted on 2/5/13 at 09:37 AM Reply With Quote
must be local company who do laser cutting.
mcerd1
posted on 2/5/13 at 11:05 AM Reply With Quote
me too
a few of us can even help you out with a CAD drawing to send to him
theprisioner
posted on 2/5/13 at 11:06 AM Reply With Quote
See ebay item: 160568904590 cut thru 6mm plate like butter all you need is an arbour and an mt3 pillar drill
theconrodkid
posted on 2/5/13 at 03:48 PM Reply With Quote
cheers peeps,off to screwfix in the morning
who cares who wins
pass the pork pies
