Author: Subject: engraving tool?
jps
posted on 11/5/13 at 06:29 AM Reply With Quote
engraving tool?
having never bought one before, could someone point me in the direction of an appropriate tool to engrave the vin into a chasis rail/ or a metal plate?
I've seen some engraving tools on ebay fo r under 20 quid but that doesn't seem reassuringly expensive enough, on the other hand over 100 for a dremel and attachments ( as seen in b and q) seems quite a lot if I only use it to mark the vin!
[Edited on 11/5/13 by jps]
Coopz
posted on 11/5/13 at 06:43 AM Reply With Quote
I used one of these, however not the easiest thing to do. I would suggest spend a little bit more and get the £29.99 kit as this includes a diamond engraving point, which is a lot better than the carbide one.
http://www.amazon.co.uk/Dremel-F0130290JF-Engraver/dp/B000QGHR1I/ref=sr_1_2?ie=UTF8&qid=1368254086&sr=8-2&keywords=dremel+engraver
http://www.amazon.co.uk/Dremel-F0130290JK-Hobby-Engraver/dp/B002LARRRQ/ref=sr_1_1?ie=UTF8&qid=1368254528&sr=8-1&keywords=dremel+engraver r />
[Edited on 11/5/13 by Coopz]
posted on 11/5/13 at 06:48 AM Reply With Quote
A set of punches is cheaper and IMHO easier to get better results with.
Note that a vin plate must be permanently attached to the chassis. Riveting it on is likely to fail, better to weld on.
mark chandler
posted on 11/5/13 at 08:28 AM Reply With Quote
Punches are much better, or get an engraving shop to make a couple in steel and just tack weld in place.
posted on 11/5/13 at 08:36 AM Reply With Quote
I use a cheap Aldi Dremel copy with a small burr for marking but as above letter punches are easier and more permanent. I cut a strip of 16g and stamp then weld onto the chassis tube. One thing I find is start at the end and work backwards, it's easier to keep the stamps in line and evenly spaced.
[Edited on 11/5/13 by Peteff]
designer
posted on 11/5/13 at 08:59 AM Reply With Quote
Punches every time.
Coopz
IMO punches are better if stamping a VIN plate then welding to the chassis, but if stamping directly into the chassis they just dent the chassis and fail to punch the letter/number clearly, an engraver does a far neater job.
40inches
posted on 11/5/13 at 09:04 AM Reply With Quote
I got a £5 battery one from Lidl, has a diamond tip and worked well.
Litemoth
posted on 11/5/13 at 02:13 PM Reply With Quote
Key makers and dog tag type places in the market will have a pantograph "Gravograph" type machine to do it neatly. How may times will you use an engraver after buying one for this??
