Author: Subject: exhaust wrap what type and how much?
baz-R
posted on 17/5/13 at 03:51 PM Reply With Quote
i need to wrap my exhaust its browning up my grp nicely!
i have a 4-1 very long branch exhaust and want to know what width and length i will need and also if anyone could point out any good or bad makes out there
i take it 1" wide is for tight bends? and hear wetting helps fitment
idealy as i have alot of visible exhaust out the side of my car somthing that looks half decent would be nice (black or titainium)
Simon
posted on 17/5/13 at 06:02 PM Reply With Quote
Got mine from CBS along with stainless straps. Iirc they do 1" and 2" rolls in 50' lengths (check their website). You'll need to calculate how much you want (dia of pipes/overlap, how far you want to cover and no of pipes.
Once on, run engine up to temp for a while cos it smokes like a lot
Simon
Ian Jones
posted on 17/5/13 at 06:36 PM Reply With Quote
this is very good exhaust wrap.
it is the same fiber as dei titnaium and about half the cost. the dei is made over seas and imported in.
the stuff in the link above, the fiber is imported into the uk, and woven here. it also has a tighter weave.
it is 100x better than the cheap glass fiber stuff.
Magmawrap Exhaust Wrap 50mm x 1.5mm x 30 Metres | eBay
maccavvy
posted on 17/5/13 at 08:00 PM Reply With Quote
ive got the thermal velocity g force wrap.
does its job a treat but I ordered some more tyraps off ebay.
I got the 20m one and enough to do my pinto 4 branch twice.
Understeer , when the front hits a wall
Oversteer, when the back hits a wall
Horsepower ,how fast you hit the wall
Torque ,how far you take the wall with you
SPYDER
posted on 18/5/13 at 08:45 PM Reply With Quote
I have just wrapped my new manifold and link pipe in "Volcano Wrap" off ebay. It's made from lava rock like the MAGMA WRAP already recommended. It's loads stronger than the glass fibre stuff and is supposed to be abrasion resistant. I bought the 2" stuff and it still went round tight bends OK. Not cheap though, but deffo better looking and hopefully longer lasting.
I put a lock wire lattice around the wrap on the link pipe to help it stay put even better.
[img][/img]
[img][/img]
[img][/img]
