Author: Subject: CVH Turbo/ Zetec engine options?
six mad
posted on 27/5/13 at 05:54 PM Reply With Quote
Evening all,
I have purchased a new project, a Raw Striker
It currently has a RS turbo engine fitted, which is fine and is quick even at low boost
The engine has been tuned with bigger injectors/rebuilt turbo.
I have a 2.0 zetec which is in my shed, I am wondering if I should put this to good
use, assuming the existing cvh is good and making good power would you guys change it?
How much is involved will the engine mountings and clutch/flywheel etc need to be changed?
Also would the zetec bottom end by an option on the cvh top end.
Just wondering if its a worth while change and best route from your experience.
Thanks in advance.
silky16v
posted on 27/5/13 at 06:28 PM Reply With Quote
i'd leave the RS turbo in more power and torque
madteg
posted on 27/5/13 at 06:44 PM Reply With Quote
Rebuild the zetec with forged pistons and lower compresion ratio. When the cvh goes bang hou are ready to fit zetec bottom end
six mad
Sorry,
I was not clear in my first post.
The turbo would stay (I love them) either way, the car also has a very nice charge cooler set up which I
would also use.
big_wasa
posted on 27/5/13 at 07:14 PM Reply With Quote
May as well enjoy it as it is, but build the zetec as a winter project for when the cvh lets go.
six mad
posted on 27/5/13 at 07:43 PM Reply With Quote
Hmm second person referencing the cvh letting go!?
Whats the problem with them catastrophic failure or just wearing out?
perksy
posted on 27/5/13 at 07:50 PM Reply With Quote
Believe they can have 'sludge' issues and benefit from Quality synthetic oil and regular changes.
I'd just have some fun with the current set up and then perhaps make a plan during the Autumn ?
big_wasa
posted on 27/5/13 at 07:59 PM Reply With Quote
Depends on condition spec and what its boosting at.
six mad
posted on 27/5/13 at 08:48 PM Reply With Quote
Checked the oil when viewing the car it was golden color so the sludge should be clear fingers crossed.
Yes sound advice, i could always turn up the wick a little
[Edited on 27/5/13 by six mad]
six mad
posted on 27/5/13 at 08:52 PM Reply With Quote
Boosting at .8 bar max at the moment, what is max boost on this engine
assuming it has standard internals and the fueling is up to the job?
pmc_3
posted on 27/5/13 at 10:03 PM Reply With Quote
Got any photos? I'm in the middle of rebuilding a car with one would be interesting to see how its plumbed in.
8psi is the max boost on standard ecu without a chip or bleed valve
six mad
posted on 27/5/13 at 10:10 PM Reply With Quote
I,m picking up the car this week, I,ll get you some pics as soon as I get it home, send me
A pm later this week as a reminder.
Scuzzle
posted on 27/5/13 at 10:21 PM Reply With Quote
If you wanted to you could ZVH it, a full blown zetec turbo would be better but since you already have all the top end gubbins you keep them and fit the bigger capacity 2.0 zetec block.
Years ago Specialised Engines charged a fortune for the 1.9 tall block imported from the U.S for bigger capacity RS Turbo power but nowadays they go for buttons because the zetec bottom ends are ten a penny.
Fair bit of fettling required and a few bits and bobs to buy but it's by no means difficult, this is a good site for reference.
http://www.jimhearne.co.uk/zvh.htm
[Edited on 27/5/13 by Scuzzle]
FASTdan
posted on 28/5/13 at 08:20 AM Reply With Quote
There's nothing wrong with a well looked after CVH turbo, they are as reliable as any engine. The only issue is with poor oil feed to one of the cam lobes - hence the 'sludge' and 'tappy' comments they're always tarnished with.
A healthy bar of boost on standard turbo will make for a very quick car and will not be stretching the engine or turbo by any means (plenty run 18-20psi). They usually put out around 180-190bhp at this boost level. Of course the relevant tweeks are needed to the fueling/management at this boost level.
I'd just keep running it and in the meantime gather the bits ready to do a zetec turbo just incase.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
six mad
posted on 28/5/13 at 09:48 AM Reply With Quote
Thanks for the info
My car has the EFI/inlet engine fitted, i have seen this manifold on a few zetecs does this require an adapter plate?
I know the exhaust manifold requires the adapter plate from previous experience.
SteveRST
posted on 31/5/13 at 01:49 PM Reply With Quote
Well I've just finished doing this exact conversion!
Click here for my Zetec Turbo Build thread, but I haven't added a new post for ages.
My Westfield had a Fiesta RS Turbo engine in it with a larger T3 turbo from a cossie. It was running the standard Fiesta Turbo EFI inlet manifold, ecu, 8 psi boost and CVH turbo exhaust manifold.
Over the winter I converted it to 2.0 silver-top zetec turbo with Fiesta RS1800 Zetec inlet manifold and throttle body, Vauxhall VXR injectors, and Megasquirt 3 ecu.
I'd budgeted around a £1100 for the project, but in the end I went further with it than I'd planned and the total figure (after selling the CVH stuff) was around £2100. However this did include new clutch & flywheel, £500 worth of Megasquirt ECU, re-wiring engine bay, Wideband lambda stuff and a Raceline sump.
Would I do it again, if I'd have know of the final cost....? Hmmm, tough one.
Some things to consider...
- your inlet and exhaust manifolds will not bolt straight to the Zetec head. They can be made to fit with adaptor plates, but I bought the exhaust manifold adaptor plate as that was my intention, and the port alignment was terrible. Exhaust flow would have been restricted too much for my liking so I sold the adaptor plate and used a CVH manifold with the CVH flange cut off, and a Zetec flange welded on - port aligment is perfect, and it meant that the turbo was pretty much in the same place as before, so I could use the existing exhaust.
- alternator is on the opposite side on a zetec. I couldn't make the CVH one fit so that was an alternator and mounting kit that I hadn't budgeted for.
- engine mounts. On the Westfield the passenger mount is essentially the same, but a new drivers side mount was required.
- clutch/flywheel. I changed from a CVH EFI flywheel and a Mk2 escort clutch to a Zetec 1.8 flywheel and Pinto 2.0 clutch. These were new and the flywheel was drilled to accept the Pinto clutch. There are many different opinions on the best clutch/flywheel combo for a RWD Zetec, so lots of ways to do it and maybe you can keep your existing set up. I had to change though, as the clutch that the CVH was using was only 190mm, so wouldn't have lasted long anyway.
- starter motor. No problem, still using CVH starter.
Been running for a month now and clocked up 1500 miles.
Running 11.5 psi boost and self mapped using Megasquirt software.
Seems much more torquey low down than the CVH turbo did. Obviously it's more powerful/quicker. I'm actually really enjoying messing about with the Megasquirt software and learning lots.
OLD CVH TURBO:
NEW ZETEC TURBO GOING IN:
Six Mad - where abouts are you? Got any pics of the current set up? What charge cooler have you got?
six mad
posted on 1/6/13 at 03:29 PM Reply With Quote
Hi Steve
Thanks for sharing great info and project. I,m in north Yorkshire, near Selby.
My charge cooler good question i,m not sure but it seems to keep the temps down as it has a temp
sensor fitted.
[img] Description
[/img]
Yes i noticed a lack of torque at lower revs my turbo zetec was such a rush from 2000rpm.
This is ok though i,m looking for a little more boost already
I hope you dont mind a may have a few questions over winter
SteveRST
posted on 4/6/13 at 02:49 PM Reply With Quote
Thanks for the reply and the pics - it's always interesting to see how others have gone about something like this. I'm not sure what that charge cooler is, but it looks pretty beefy and up to the job.
Yes, sure - feel free to msg me about the zetec turbo build. I'm still tweaking a few small things even now, for example I've just got the VDO rev counter to run off the megasquirt ecu. It wasn't straight forward but got there in the end!
