Author: Subject: Stack Dash tacho needle
richiekuk
posted on 4/6/13 at 02:17 PM Reply With Quote
hey all.
Have noticed recently that my tacho needle on my Stack (ST700), tends to jump around alot. I'd say it jumps around more than it doesnt. Its quite annoying as its the only way i can see my RPM!
The car is an R1 engined Fury. Not sure if its because of the tacho feed from the engine, or the Stack itself.
Anyone had a similar issue?
Richie K
sdh2903
posted on 4/6/13 at 02:26 PM Reply With Quote
Funny you say that as my stack water temp gauge has just started to do this. I have the st500 and the needle is fairly steady, if it starts to loose the rpm signal it tends to just go to zero as it happened when I had a connection come loose on a coil.
