Author: Subject: Car cutting out
Fieldy
posted on 10/6/13 at 02:42 PM Reply With Quote
Car cutting out
Hi Guys
Car – R1 Engine (injection) Locust
After a little bit of advice please, haven’t used the car since September and have only started it once, came to start it a week ago and the battery was knackered. I took the battery off my motorbike (02 R1) and bolted that into the car. I started it up and it fired first time. I then left it to sit for while to warm up before taking it around the block to dust off the cobwebs. I got a short distance and all was fine until I noticed the engine light was flickering on and off and the gear indicator gauge was flicking on and off. The car then cut out.
As I was moving I jumped the car and it started again, went another 20 metres down the road and did the same thing. At this point I pulled over thinking I hadn’t attached the battery properly but everything was tight and where it should be. Got back in the car and started it again (started first time) and I got almost back to my house before one last cut out… again it started straight away and I got back to my house.
I’m no electrical specialist and haven’t had chance to look at anything yet, but wondered if anyone has any initial thoughts as to what this could be? I find it odd that it starts straight away again without me doing anything
Look forward to some genius answers :-)
Thanks in advance
Norfolkluegojnr
posted on 10/6/13 at 03:00 PM Reply With Quote
Sounds like a charging issue to me.
I'd get a multimeter over the battery with the engine running to see if its charging. Don't know bike engines that well, but its whatever the equivalent of the alternator is that might be the issue (generator?).
first thing to rule out anyway.
Fieldy
posted on 10/6/13 at 03:04 PM Reply With Quote
Sorry i should have pointed out that the battery i installed is only a few weeks old as the motorbike battery was knackered too. Im going to order a new one for the car as it is slightly bigger. I would think that would rule out a charging issue though?
To also add the car ran fine when i used it last year.
Matt
scimjim
sounds like a loose connection - wiggle the battery wires and ECU loom with the engine running.
Norfolkluegojnr
posted on 10/6/13 at 03:07 PM Reply With Quote
if the engine isn't charging the battery, eventually you will run out of electricity in a full charged new battery, just the same as an old one. its simple check and would rule that out. you ideally want 14v at the battery.
could be a loose conenction as mentioned above - check all your earth points are good, but my moneys on something being up with the charging
either way, should be an easy fix!
ReMan
posted on 10/6/13 at 03:17 PM Reply With Quote
As it still re-starts, its got to be a dodgy /wobbly connection somewhere, not that the battery is not charging. Unless the regulator has developed a fult that manifests when the volts/revs go up to running speed, tho R1 reqs are not renowned to fail
Possibly an earth, but any other connector in the sceme of things.
Unless youve messed with anything that might have dislodged somthing in the vicinity then you just need to start undoing ad re-doing all your connectors. Could even be a bit of damp/corrosion in the ecu or regulator connector
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Slimy38
posted on 10/6/13 at 03:19 PM Reply With Quote
I'd put my money on a dodgy connection causing the charging issue! I'd particularly look around near the battery (and it's connection to the chassis), if you've replaced the battery you've disturbed wires. And the fact that it works for a period of time does point to a loose connection, or even a broken wire. A discharged battery would stay discharged, you wouldn't have got it home.
[Edited on 10/6/13 by Slimy38]
olimarler
posted on 10/6/13 at 05:57 PM Reply With Quote
After my recent events I'd say dodgy earth somewhere. Especially if its been sitting around
