Author: Subject: Bike carb jetting for iva
davidimurray
posted on 16/6/13 at 09:43 AM Reply With Quote
The iva test centre is less than 2 miles from my home so I am planning on driving my car over.
I have a1.8 pinto which is fitted with zx6r carbs. The jetting is as standard but I have raised the needles one groove.
I haven't setup the emissions finally yet(I've got a wideband and a gas tester) but I was thinking that as the test is only at idle and fast idle with no load then it won't actually be using the main jet.
Hence I was wondering if I will be OK driving to the iva on standard main jets ,with the needles one notch higher, if I take it easy or should I re-drill them to open them up. Once iva is done I can do some road tuning with the wideband and set the final jet sizes
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
jacko
posted on 16/6/13 at 05:53 PM Reply With Quote
I don't know if you know but it needs to be 3.5 co and 1200 hc for a pinto
Do you know what size holes are in your main jets at the moment ?
at a guess i would think 1.5 to 1.6 would be about right for a 1800cc
It also depends on other thinks like what cam you have fitted
Can you get it to a MOT testing station to help set it up
Jacko
maccavvy
posted on 18/6/13 at 05:01 AM Reply With Quote
ive just had by oe spec pinto set up with fireblade carbs. The jets were 1.3mm and they were spot on for setting up.
Beware going too large its more difficult to make the hole smaller.
Understeer , when the front hits a wall
Oversteer, when the back hits a wall
Horsepower ,how fast you hit the wall
Torque ,how far you take the wall with you
