Author: Subject: duratec flywheels
mikey p
posted on 24/6/13 at 08:05 AM Reply With Quote
duratec flywheels
Just wondered if someone can confirm the number of teeth and diameters of the two different flywheel sizes fitted to Duratec's?
I have two different ones one being 112 teeth and one 110, and need a starter motor to match....
I think the 110 teeth version is the single mass st150 version and the 112 is the DMF size?
What was the 112 tooth variant fitted to? all Mondeo Duratec's? both 1.8 and 2.0L? and Cmax? Smax? Focus? etc.
Thanks Mike
big-vee-twin
posted on 24/6/13 at 03:50 PM Reply With Quote
The mondeo starter is for the slightly larger fylwheel, so the mondeo starter is the one to avoid. Flakmonkey used one and had to turn some thickness of the mounting flange to make it fit.
My engine is ST150 and had plain flywheel can use the Focus one which I did or the ST150 obviously.
http://www.triangleltd.com
beaver34
posted on 24/6/13 at 04:26 PM Reply With Quote
if you get the part numbers from both i can tell you what its from and then what starter you need to go with them
dave r
posted on 24/6/13 at 08:47 PM Reply With Quote
mine is focus st flywheel
running at mondeo dual mass starter, with about 3mm machined off the faces
seems ok
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
