Author: Subject: sd1 clutch slave girling code=?
Chris_Xtreme
posted on 1/7/13 at 11:43 AM Reply With Quote
I am after some help working out what this slave sylinder is.
From the builder, the notes just say sd1 slave cylinder. (and also a rebuild kit was bought at build time) I bought a sd1 slave rebuild kit from rimmerbross before I removed the slave unit, but there is no circlip on mine to remove.. it looks like a sort of sealed unit.
On it is stamped:
GIRLING Q138 ( i think it is an 8)
and on the other side:
74660078 (the best I can guess i the 78 at the end)
google doesn't seem to be helping me, nor the usual places to buy.
I'm looking to replace it whilst I have the system in bits!
any help appreciated.
cheers
Chris
posted on 1/7/13 at 01:34 PM Reply With Quote
Overhaul kits fit a number of different cylinders.
Personally I would have gone straight for a new Landrover Defender cylinder which are cheap as chip from LR specialists.
davred
posted on 1/7/13 at 02:27 PM Reply With Quote
V8 SLAVE CYL
HI CHRIS
GIRLING PT NO PJ154 OR LPR NO 3524B REPAIR KIT GIRLING SP4190 HTH DAVID
davred
posted on 1/7/13 at 02:30 PM Reply With Quote
CHRIS
TRY PAST PARTS BURY ST EDMUNDS 01284 750729 VERY HELPFUL AND THEY DO POST IT OUT HTH DAVID
Chris_Xtreme
posted on 1/7/13 at 06:30 PM Reply With Quote
Thanks for the pointers, really want to just replace it like for like, as i have read they all can have different bore, length and thread size for the bleed and in point.
Will give past parts a try tomorrow good idea. Cheers Chris
scudderfish
posted on 1/7/13 at 07:05 PM Reply With Quote
Are you local to me? I have a new unused one lying on my bench.
Chris_Xtreme
posted on 1/7/13 at 08:53 PM Reply With Quote
If the car was on the road i reckon i could say yes! But no not really. I'm down nr wimbledon sw london.
What are the numbers on the one you have if you don't mind telling me? Is it the same as i guessed for mine? If so where did you buy it from ?
scudderfish
posted on 2/7/13 at 06:16 PM Reply With Quote
I suspect it was from eBay. Not much in the way of identifiers on it I'm afraid :-
Chris_Xtreme
posted on 2/7/13 at 07:33 PM Reply With Quote
thanks.. it certainly looks like mine - but who knows as the numbers are so different!
appreciate the time to take the pic.
my master cylinder is a ap racing one it turned out so it could fit in the space.
http://www.apracing.com/product_details/race_car/master_cylinders/flange_mounted_types/vertical_flange_types/cp5623_type.aspx
so really want to replace the slave like for like so the same effect is felt.
