Author: Subject: IVA Fog Light
rdodger
posted on 1/7/13 at 04:07 PM Reply With Quote
IVA Fog Light
I failed IVA today on the fog light. It is a Wipac 95mm E marked one. Landrover 90 / defender style.
It failed because it wasn't marked with an F or B.
So far I have only found and LED one from CBS £42 inc VAT plus postage so that would be £49! or a nasty square bolt on under bumper style one £8.40 + postage.
The note in the manual refers to Note 2: evidence that the lamp gives suitable intensity has been provided.
Looking at it and seeing that it is very bright doesn't seem to cut it.
HELP!
rdodger
posted on 1/7/13 at 04:10 PM Reply With Quote
Phew saved!
http://www.s-v-c.co.uk/product/fresnel-lens-fog/
£13 inc vat!
loggyboy
posted on 1/7/13 at 04:16 PM Reply With Quote
Summary of Rear Fog requirements (Sec 28):
Min 1, Max 2 (An optional rear fog lamp must form a matched pair with the obligatory lamp.)
One must be on centreline OR on offside (drivers).
Min Seperation from stop light, 100mm
Max Height 1000mm
Min Height 250mm
Fitted so that the reflector is facing squarely to the rear
All rear fog lamps must display an “e” or “E” mark with a “B” or “F”
The rear fog lamp(s) must only illuminate when dipped beam, main beam or front fog lamps are lit (See Note 3) (Note 3: front fog lamps may be illuminated with the side lamps only.)
There is also a new ruling in the latest revision that states that the light must be automatically switch off after the ignition has been switched off and only be switched back on when the switch is pressed again.
Pretty sure I recall looking at this one in Eurocar parts and it had an 'F',
Dual Mount Rear Fog Lamp Ring / Includes Bulb &' Bracket RL014 | eBay
[Edited on 1-7-13 by loggyboy]
Mistral Motorsport
davidimurray
posted on 1/7/13 at 05:20 PM Reply With Quote
The general consensus seems to be it only needs to go off and not come back on if they come on with sidelights
Max Height 1000mm
Min Height 250mm
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
rdodger
posted on 1/7/13 at 05:23 PM Reply With Quote
That's correct
My tester made sure the fog light didn't come on with side lights only dipped beam. He checked at least twice!
johnwilders
posted on 1/7/13 at 07:26 PM Reply With Quote
I fitted the cheepo for the test, think it must have fallen off on the way home.
GOJO
posted on 1/7/13 at 09:36 PM Reply With Quote
Mine failed on this , bolted a cheapie on a bracket from rear chassis so as not to damage rear bodywork and put and plastic blank over where your other fog was fitted .
Some stuff is just crazy and make sure you u trim the bracket if you go that route.
daveb666
posted on 2/7/13 at 09:34 AM Reply With Quote
Rodger; just checked mine. It has F on it twice lol
The Black Flash
posted on 3/7/13 at 12:31 PM Reply With Quote
Always good to check - I got sent a brake light instead, which looked identical except for the F or B marking. Would have been an annoying fail!
