Author: Subject: Megablade rev counter help?
Andy3004
posted on 21/7/13 at 05:12 PM Reply With Quote
Hi All,
Really hope someone could help with this!
I have a Sylva Striker with a 919 fireblade engine. Up until now it's been running the standard bike instruments.
I've got hold of (via ebay) an unused westfield megablade (supposedly) rev counter. It's actually an eliott rev counter (14k max) but is stamped westfield on the face. Today I installed it, and wired the tacho feed from the bike loom to the new tacho.
So to the problem - on starting, the rev counter works but is reading double what the engine is actually doing - ie 2k rpm at idle, 8k at 4k revs etc.
My limited understanding of electrics tells me i need to use an alternative source for the rev counter....based on the fact there's two coils with a wasted spark.... so to my question - I was planning on taking a feed from one of the wires to the twin coils instead of the bike tacho feed to drive the new rev counter - am I correct? if so, any recommendations to which wire?
can someone tell me if I'm right in this?
Many thanks in advance!
Regards
zekill
posted on 21/7/13 at 06:19 PM Reply With Quote
If there isn't setup on this rev counter you can try to pick signal from one coil.
Fisher Fury with Phoenix bodywork, Blade 919cc
Andy3004
posted on 21/7/13 at 06:33 PM Reply With Quote
No there isn't a setup on this one - think it's pretty old!
Thanks for that though -you've confirmed my thinking so will try that!
Appreciate the input
Regards
