Author: Subject: Re: Self-centring & Tyre press
Dick Axtell
posted on 24/7/13 at 03:05 PM Reply With Quote
Have searched thru the various threads on this, and am now confused. There seems to be some variance in views on tyre pressures needed to procuce IVA-satisfactory self-centring effect.
Possibly some differing views depending on whether Sierra or Cortina hubs are used. I have used Cortina uprights, with upper wishbones giving what seems to be approx 3 deg castor. Had the car front end fully tracked, camber angles adjusted and toe-in set at Procomp. Matt and Ivan did a great job, and offered useful advice; big thanks to them.
So, the question is - what tyre pressure should I set for the fronts? One view suggested low pressure e.g. 16 psi, another view reckoned it should be 40 psi, just for the (re-) test.
Your suggestions please.
daveb666
posted on 24/7/13 at 03:10 PM Reply With Quote
I increased my tyre pressure from 28psi to 35psi for the IVA and noticed an improvement (all be it not that significant) and mine passed OK; that said - could have been fine on the normal pressures.
theprisioner
posted on 24/7/13 at 03:15 PM Reply With Quote
I was wondering the same thing prior to IVA and I was told (by someone on this forum) they recommended 8psi at the front to get a J15 thru (because Bently do that). On the day I forgot to lower them and it passed anyway. The self centring on my car is barely perceptible only if the camber is in my favour. My pre-prepared excuse was "that all the bits are new and a bit sticky".
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
big_wasa
posted on 24/7/13 at 03:22 PM Reply With Quote
The best way is to get a new set of top wishbones with the full and designed 7 deg.
Replacing the rubber bush on the steering column with the bearing mod also helps no end.
[Edited on 24/7/13 by big_wasa]
posted on 24/7/13 at 03:38 PM Reply With Quote
Good tip on the steering bushes, the more free running they are the better for self-centering and general feel.
907
posted on 24/7/13 at 04:21 PM Reply With Quote
Every now and then someone posts a reply that's spot on, 100% common sense.
It's a shame they are not more frequent.
Paul G
panichat
posted on 24/7/13 at 04:27 PM Reply With Quote
What worked for me...
- check the free movement of the steering rack - if the damper is too tight it can make it too stiff to center well (particularly if you only have 3 degrees of castor). You can add another shim very easily.
Dave
Dick Axtell
posted on 24/7/13 at 07:28 PM Reply With Quote
What bearing mod? Please can you point me to the right thread?
Found it!! See here - http://www.locostbuilders.co.uk/viewthread.php?tid=183202
And thanks to everyone else for their feedback. Wishbone mod for the future; re-test next Mon. Lack of self-centring is the remaining critical issue.
[Edited on 25/7/13 by Dick Axtell]
