Author: Subject: Can I put a boat on by roof?
richard thomas
posted on 7/8/13 at 05:03 PM Reply With Quote
Hallo all,
Been searching the net for an answer....but as usual need to ask here for good advice.....:-)
I bought an inflatable dinghy (4 metres long, 50 Kg) today want to take it to France with my caravan and Land Rover Disco 2.
Rather than deflate it, can anyone think of a good reason why I can't simply invert it and strap it to the standard roof rails? Notwithstanding the load capacity of the standard rails, the bulk of the weight will be taken by the roof itself....the rails will just be securing the boat with ratchet straps....
It might look a bit odd, bit like a rather large canoe that is a common sight these days...
Any thoughts?
sdh2903
posted on 7/8/13 at 05:06 PM Reply With Quote
I've done it a few times no problem just keep the front end tied down well to stop it lifting.
stevebubs
posted on 7/8/13 at 05:22 PM Reply With Quote
Ditto - my primary concern would be the forces on the roof generated by the lift...if you keep the lift to a minimum then you're probably ok...last thing you want is a huge airbrake...
On slightly different note - would you not be worried about something puncturing it?
PSpirine
posted on 7/8/13 at 05:38 PM Reply With Quote
The best reason I can think of is that it will make your already poor MPG considerably worse.
Depending where in France you're going keeping the dinghy inflated could well cost you a few beers!
coyoteboy
posted on 7/8/13 at 06:01 PM Reply With Quote
? Like what?
We've carried inflateables (3-4m) on the roof of our boat (6m) on its trailer loads. Never deflates (but in the sun you need to be careful of over-inflation and overheat).
richard thomas
posted on 7/8/13 at 06:21 PM Reply With Quote
Thanks all,
After my missus expressed extreme concern based on absolutely nothing substantiated, I have deflated it and crammed it in the back of the disco.....it's VERY tight in the back now, but I sit in the front so who cares lol
stevebubs
posted on 7/8/13 at 06:43 PM Reply With Quote
? Like what?
The same things that fly up and crack your windscreen....I don't know how strong these inflatables are...and guess that depends on the make...
[Edited on 7/8/13 by stevebubs]
jossey
posted on 7/8/13 at 07:45 PM Reply With Quote
will it not fit in caravan? do you have a big back or front window etc?
David Johnson
iank
posted on 7/8/13 at 08:21 PM Reply With Quote
Other potential problem is scratching of the roof as it moves around slightly, especially if it's been on a sandy beach.
Anonymous
SteveWalker
posted on 7/8/13 at 09:55 PM Reply With Quote
That was my thought. You can get a lot in a caravan.
Many years ago my parents bought a house in France, we designed and built a new staircase which, disassembled, just fitted in a Sprite Musketeer as long as it was lifted a foot or so off the floor.
A later trip took all the old kitchen units from home over - as I was helping load, a neighbour said "everything but the kitchen sink", whereupon I reached in, lifted out the sink and said "we've got that too."
richard thomas
posted on 8/8/13 at 03:18 PM Reply With Quote
I did try....I've got my 6 foot dinghy in the caravan but there is no way this one will fit in......:-)
motorcycle_mayhem
posted on 8/8/13 at 03:48 PM Reply With Quote
I had a Laser dinghy on the roof of my 109 SII, for a few years. Getting it up there was the main problem, not easy.
The only concern was from the Norwegian police, who were (at that time at least, some years ago) concerned about high roof loads and high vehicles carrying them.
I've seen a few inflatables on the roof of many a vehicle heading up and down the A30 to Cornwall, so clearly of no concern to anybody. As for puncture, OK I'm a cynical and paranoid old fa.. and my love for this country and it's fine people is underwhelming, but my concern would be a fellow citizen puncturing it for pleasure.
mcerd1
posted on 8/8/13 at 04:00 PM Reply With Quote
yeah, you need a couple of tall people to make that one easy...
my dad's mate sometimes has a laser, 2 kayakand 5 bikes on his 90's roof while towing either a decent size speedboat or a very large caravan (either of which is sure to be rammed full of stuff)
a prpper roof rack helps alot though...
