Author: Subject: Locost - can you remove engine and box under the car?
puma931
posted on 25/8/13 at 09:10 PM Reply With Quote
Once the prop is removed, can you lift the chassis up to leave the engine and gearbox (xflow), or do you have to lift the engine n box out?
[Edited on 25/8/13 by puma931]
jps
posted on 25/8/13 at 09:19 PM Reply With Quote
in the Haynes book it suggests you can do this with a pinto, depends how far the gearbox output shaft sticks into the tunnel I guess?
Smoking Frog
posted on 25/8/13 at 10:53 PM Reply With Quote
I would say yes, as I put my engine in this way (MK Indy with MX5 1600 engine). May have to remove rad and jiggle the chassis about a bit.
puma931
posted on 26/8/13 at 06:18 AM Reply With Quote
Cool. I will give it a go. Thanks Mathew
posted on 26/8/13 at 08:18 AM Reply With Quote
Are there any cross members in the tunnel under the gearbox tail shaft ?
pewe
posted on 26/8/13 at 10:23 AM Reply With Quote
If you can't, try putting the rear end up on ramps as this gives a better angle to remove engine and box from the top.
HTH.
Cheers, Pewe10
Nurburg2006
posted on 26/8/13 at 10:24 AM Reply With Quote
There is a rear gearbox mount. Yes it will go out the bottom that's how I got my xflow.
