Author: Subject: Should a fuel pump have continuity across the terminals?
twybrow
posted on 12/9/13 at 09:27 PM Reply With Quote
Just doing some more testing now I know my ECU is dead (trying to track down why), and I was chasing a 2ohm resistance to earth on the fuel pump/injector power feed wire. So I unplugged everything on the circuit (injectors, fuel pump relay and finally the fuel pump) and have found that I had intermittent continuity via the fuel pump. It seems there is a dodgy +ve wire going into the connector block, as when I wiggle the wire with the plug attached to the fuel pump, the connection to earth keeps breaking.
I then disconnected the wiring, and tested the pump directly, and it seems to have continuity across the terminals. Is this normal? Should a bike fuel pump have continuity across the terminals?
adithorp
posted on 12/9/13 at 09:54 PM Reply With Quote
It's an electric motor so I'd expect continuity. Could be wrong though.
http://jpsc.org.uk/forum/
plentywahalla
posted on 12/9/13 at 10:45 PM Reply With Quote
'Continuity' implies zero or near zero resistance. Their should be a measurable resistance. Find out what the wattage of the motor is and calculate the expected resistance and compare with the actual. An electric motor usually fails because the insulation within the windings breaks down which will cause the resitance to drop.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
r1_pete
posted on 13/9/13 at 06:42 AM Reply With Quote
Is the 2 Ohm impedance across the pump terminals what you refer to as continuity when you wiggle the plug? if so, from Ohms law you have a pump which is drawing 6 Amps at 12v, and is consuming 72 Watts, but it would seem there is an internal problem in the wiring which is causing the intermittant open circuit.
posted on 13/9/13 at 12:18 PM Reply With Quote
A motor is not a resistive load! The resistance of windings will only tell you what the stalled current will be, and is not directly related to the motors rated power.
The bottom line is that a DC motor will normally have a low resistance across the power connections.
Julian Thrussell
posted on 12/11/13 at 01:16 PM Reply With Quote
put 12v on it and see if it works?
